A different twist on switch debounce
MrDEB
If I am interpreting this right then the DELAYMS(xxx) increases. Note I am not familiar with this code, assume its C??
Just browsing for tilt switches and found this.
    /* Better Debouncer
    * This debouncing circuit is more rugged, and will work with tilt switches!
    * http://www.ladyada.net/learn/sensor/tilt.html
    int inPin = 2; // the number of the input pin
    int outPin = 13; // the number of the output pin
    int LEDstate = HIGH; // the current state of the output pin
    int reading; // the current reading from the input pin
    int previous = LOW; // the previous reading from the input pin
    // the follow variables are long's because the time, measured in miliseconds,
    // will quickly become a bigger number than can be stored in an int.
    long time = 0; // the last time the output pin was toggled
    long debounce = 50; // the debounce time, increase if the output flickers
    void setup()
    pinMode(inPin, INPUT);
    digitalWrite(inPin, HIGH); // turn on the built in pull-up resistor
    pinMode(outPin, OUTPUT);
    void loop()
    int switchstate;
    reading = digitalRead(inPin);
    // If the switch changed, due to bounce or pressing...
    if (reading != previous) {
    // reset the debouncing timer
    time = millis();
    if ((millis() - time) > debounce) {
    // whatever the switch is at, its been there for a long time
    // so lets settle on it!
    switchstate = reading;
    // Now invert the output on the pin13 LED
    if (switchstate == HIGH)
    LEDstate = LOW;
    else
    LEDstate = HIGH;
    digitalWrite(outPin, LEDstate);
    // Save the last reading so we keep a running tally
    previous = reading;
Its a snippet from an arduino sketch... Even 50mS for me is too short... But as he uses this for tilt switches I'm sure its good..
Normal debounce is 20 - 30mS.... With my keypad I use a beeper 100mS+ to acknowledge the keypress.... Works fine..
