8085 weird problem
prescott2006
we were requested to interface 8085 with memory and led,then a routine need to be written to make the led light up one at a time with delay 1 second.we have simulate the program and it run perfectly but when we test on the circuit we built it doesn't work.after a lot of trial and error,finally we found that answer,the 8085 does not recognize DCX,it only recognize DCR,so we only change the DCX in our original program to DCR to perform delay.do you guy know why the 8085 behave like this?simply does not recognize the DCX instruction.our lecturer also say never seen this before.
Most likely it is your assembler/compiler that doesn't understand the DCX instruction. Have you looked at the HEX code (decompiled it)?
Your simulator will establish initial conditions that are not guaranteed on an actual microprocessor. If I recall correctly, the 8085 "hardware reset" is simply a non-maskable interrupt vectored to 0000H. No registers are initialized!
Did you initialize the register pair before using it?
If your using a 8 bit data slice then you should use DCR, I think DCX is for two bytes. I never used 8085 instruction set before as it is so old but that is my guess.
Good catch! Most importantly, DCX does not affect flags, so it would appear that the instruction is ignored.
I'll bet the trainer/simulator mistakenly sets the flags!
