555 ic+output pulse after trigger pulse ends
Mindmywork
im working on a circuit which will be triggered by cell phone audio output. im able to amplify the audio signal, the voltage has spikes in it from 1.6 to 4.5v when the ringtone is playing.
so can i take it as a input to 555 and get a pulse of 5 seconds as output.
output pulse should start after the ringtone ends.
You mean when the ringing totally stops or at the end of the first ring?
If at the end of the ringing, what is the period between rings?
How long does the ringtone last? Does it have gaps in it?
You might find you need two 555s: one triggered at the start of the ringtone and the other triggered when the pulse from the first one goes low.
after total ring stops. like i will call the mobile the ringtone plays and stops, after the ringtone stopped the output has to be triggered.
good idea. cant we do it with just a single 555
