4X4 Dual Battery Monitor
Axle_80
Hi everyone,
So I'm trying to program a replacement pic16f818 to operate a dual battery monitor but as this is my first ever pic project I'm having some difficulty.
I'v attached the Schematic which uses Charlieplexing for the led indicators and the code I have so far.
The problems I'm facing right now are the code is too large for the pic and I don't know how to reduce it and also the ADC doesn't operate on both channels.
If I comment out the code for one channel the other will work.
any help here would be much appreciated.
Thanks.
float VM;
float VA;
void main(void){
    OSCCON = 0b01110000;
    TRISA = 0b00000011;
    TRISBbits.TRISB6 = 1;
    TRISBbits.TRISB7 = 1;
    PORTAbits.RA6=0;
    PORTAbits.RA2=1;
    ADCON1 = 0b00000100;
       while(1){
// ADC RA0
    ADCON0 = 0b11000001;
    //PIR1bits.ADIF = 0; //Clear ADIF bit
    ADCON0bits.GO_DONE = 1;
    if (ADCON0bits.GO_DONE==0)VM = (ADRESH*0.01960784)*3;
    if (VM>11.4){TRISB = 0b11101110,PORTB = 0b00000001;}//1
    __delay_ms(1);
    if (VM>11.6){PORTB = 0b00010000;}//2
    __delay_ms(1);
    if (VM>11.8){TRISB = 0b11011110,PORTB = 0b00000001;}//3
    __delay_ms(1);
    if (VM>12){PORTB = 0b00100000;}//4
    __delay_ms(1);
    if (VM>12.1){TRISB = 0b11111100,PORTB = 0b00000001;}//5
    __delay_ms(1);
    if (VM>12.2){PORTB = 0b00000010;}//6
    __delay_ms(1);
    if (VM>12.3){TRISB = 0b11111001,PORTB = 0b00000010;}//7
    __delay_ms(1);
    if (VM>12.4){PORTB = 0b00000100;}//8
    __delay_ms(1);
    if (VM>12.5){TRISB = 0b11111010,PORTB = 0b00000001;}//9
    __delay_ms(1);
    if (VM>12.6){PORTB = 0b00000100;}//10
    __delay_ms(1);
    if (VM>13){TRISB   = 0b11001111,PORTB = 0b00010000;}//11
    __delay_ms(1);
    if (VM>13.2){PORTB = 0b00100000;}//12
    __delay_ms(1);
    if (VM>13.7){TRISB = 0b11100111,PORTB = 0b00001000;}//13
    __delay_ms(1);
    if (VM>14.2){PORTB = 0b00010000;}//14
    __delay_ms(1);
    TRISB = 0b11111111;
// ADC RA1
    ADCON0 = 0b11001001;
  //  PIR1bits.ADIF = 0; //Clear ADIF bit
    if (ADCON0bits.GO_DONE==0)VA = (ADRESH*0.01960784)*3;
    if (VA>11.4){TRISB = 0b11110011,PORTB = 0b00000100;}//15
    __delay_ms(1);
    if (VA>11.6){PORTB = 0b00001000;}//16
    if (VA>11.8){TRISB = 0b11101011,PORTB = 0b00000100;}//17
    __delay_ms(1);
    if (VA>12){PORTB = 0b00010000;}//18
    if (VA>12.1){TRISB = 0b11011011,PORTB = 0b00000100;}//19
    __delay_ms(1);
    if (VA>12.2){PORTB = 0b00100000;}//20
    if (VA>12.3){TRISB = 0b11110101,PORTB = 0b00000010;}//21
    __delay_ms(1);
    if (VA>12.4){PORTB = 0b00001000;}//22
    if (VA>12.5){TRISB = 0b11101101,PORTB = 0b00000010;}//23
    __delay_ms(1);
    if (VA>12.6){PORTB = 0b00010000;}//24
    __delay_ms(1);
    if (VA>13){TRISB   = 0b11011101,PORTB = 0b00000010;}//25
    __delay_ms(1);
    if (VA>13.2){PORTB = 0b00100000;}//26
    __delay_ms(1);
    if (VA>13.7){TRISB = 0b11110110,PORTB = 0b00000001;}//27
    __delay_ms(1);
    if (VA>14.2){PORTB = 0b00001000;}//28
    __delay_ms(1);
    TRISB = 0b11111111;
  • Battery Controller Dual User Guide NLBMDAS.pdf
I can give you a hint on the a/d, however there shoudl be enough room in the pic for that code, is the compiler setup right?
As for the a/d, you switch the i/p to the a/d then do a conversion immediately, if you look at the pic datasheet there is an aquisition time, you need t wait for a period after you change the a/d channel before a conversion, try the 1ms you've been using after selecting the i/p.
Thanks Dr Pepper
I uninstalled then reinstalled xc8 then added the delay before ADCON and its now compiling the full code and working on both channels.
Your help is greatly appreciated.
