Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
As audioguru stated...... try this: in a room with no lights on, in the dark, power on the set and take note if you observe a dim glow from the LCD panel. If you can see a faint glow (or obvious glowing dark gray screen) the backlight lamps and the inverter circuitry are likely working OK. You may have a problem in the video processing section instead. If the LCD panel is dark black (as when it's powered off) then I'd suspect the lamp inverter board first, and then the lamp(s) secondly. Most lamps seem to outlast the inverter circuitry, hence why that would be suspect #1. Some inverter boards have a fuse on them that could have opened for one of more number of reasons.
Presumably this is a cheap junk make?, as such they have VERY short life spans, and poor reliability. A common problem with them is failure of the inverter transformers.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
