Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
i have a problem, i have a 433 MHz transmitter / receiver pair module. they are lying around for about an year. now i have no means of testing them. how can i test them? any help ??
i have a total of 3 receivers and 5 transmitters. all are not functioning properly, i have a query, these things come in pairs. will it work with other modules having the same frequency (433 MHz)?
i had tried the first method, sending a bit 1 through the module. but, its not received on the other end. i checked if there is any signal from my module by tuning my tv to 433 Mhz, but no artifacts . is there any other method?
Don't turn them on all at once. That'll jam the receivers. Supply one transmitter and one receiver only. Then you apply a voltage (I usually just use a 3V supply with a 1k resistor in series and apply the voltage on the Tx pin.)
As for the TV, I wouldn't bet that it'll poke the TV receivers. They have their own modulation and filters and all those monsters inside.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
