lots o' tots
Hello all.
I want to start off by saying that I am a very beginner level hobbyist.
I am looking to hook up 3 linear actuators (or something similar) in a simple toggle switch circuit. I do not need to control the actuator speed, so no control boards are desired. The simpler the better. Just a simple on and off, most likely using a DPDT switch.
The goal is to lift (push) a metal tray with a sample that weighs 50 grams in the air so that it is above a precision balance. I want to weigh the tray and sample but it will be inside an environmental chamber so i can't open the door which is the reason for using an linear actuator or something similar. After weighing, i would like to lift the tray back in the air so the balance is at 0 g.
Limitations/requirements:
I was looking at two types of linear actuators
http://www.robotshop.com/ca/en/firg...-12v-potentiometer.html#Supplier-Product-Code
and
No laughing, but i was looking at the LEGO linear actuator. they are hard to find, but still out there.
due to low duty cycle and lifting such a small mass, maybe this can work
http://www.robotshop.com/blog/en/lego-linear-actuator-3837
Can this be done? If so, could you please direct me how this sort of thing is wired or any other useful information.
thanks for your time
- My total height cannot be more than 4" which includes the extension.
- Currently, I have 2 wires available to me that passes from the outside to the inside of the chamber. I can make more openings but only if i have not other choice. It is a real pain in the butt to do.
- 3 actuators will have to work in parallel. Exact timing is not critical as i believe there is a small amount of room for error, but it should be pretty close so that an object can be lifted.
- Duty cycle is not important. It may be cycled ~100 times in ~2 months. that is about it.
and
