24V Ignition Project
jetbox
hey guys,
i was reading a thread on here a while ago where someone needed a continuous/pulsing spark for a jet engine ignitor. i have a similar need (though not for a jet :p )
i believe one of the suggestions for the poster i'm referring to was to use a 555 timer along with a car ignition coil to create the spark, which seems like a great solution, however, the supply voltage i'm dealing with is 24V. i'm fairly new to the electronics world, and the little bit i've read about 555 timers seems to suggest that they can only handle up to 16V. are there 555 timers that can handle more, or am i misunderstanding the specs i've read? any solutions/suggestions would be greatly appreciated!
One of the more obscure methods used to drive such a coil is to connect a small DC motor (that can handle 24v) in series between it and the power supply.
Another method would be to use a suitable relay, wired in the manner of the classical style "doorbell" circuit, this is perhaps not the most elegant solution as prolonged use will eventualy cause the relay to fail but it is very simple to implement and requires no specialist knowledge of electronics.
thanks for the replies guys
i think i'll give the dc motor suggestion a try since there coincidentally is also a need for a 24V fuel pump to be run :D
