Hi all,
I am trying to get a PH-CF transmitter to work with SMS controllers analogue inputs..
Here is the transmitter
https://www.omega.co.uk/ppt/pptsc.asp?ref=CDTX300
As you can see the transmitter takes the value of the PH and CF and then outputs them at between 4 - 20mA I can calibrate the system without problem using a multimeter i.e 5mS (half of CF range) = 12mA (half way between 4 and 20 mA)
They work great on there own i.e the PH side into the sms controller that is going to read the PH values or the CF side of the transmitter into the sms controller that is going to read Cf values....Until I have both on at once..when this happens the readings go crazy that the controllers read of which is due to them sharing the supplies in some fashion.
Here is the diagram provided by the company who sold me the transmitter
I have wired it exact and always the readings go crazy at the sms controller (but perfectly fine when wiring one or the other)
Here is the circuit diagrams provided with the transmitter
I have wired it in both combinations and used 3 x individual power supplies but no luck. You will notice the negatives are joined internally...I have opened the unit to confirm this. This means theres no way of seperating the supply apart from cutting the tracks inside the unit or similar. Due to the nature and affordability of this unit I am stuck with this one as I cant find anymore specific to my application that are not 3+ times the price. I have gone as far as I can with there tech support and the only option now is a refund. I am sure it is a wiring issue.
On the website I bought the transmitter from you will see this...
https://www.omega.co.uk/ppt/pptsc.asp?ref=CCT
This is a loop isolator..if all else fails with the wiring could this or something similar work?
