2 watt max FM transmitter circuit
JohnnBlade
audioguru
Greets, and cools to meet you, have been reading yr posts for years, but never had any questions.
Untill now,
Just yr advice, if i wanted to build a 3 stage or 4 stage fm transmitter of about 1.5 to 2 watt
Can i acomplish this using. 12v 3a power supply, and the only transistors i have available are the
Bc548, bc549, bc547, 2n222a, 2n2219a, 2n3866,
Can i reach the wattage im looking for with the transistors?
If so, which ones do you think are best for certain stages of the circuit to get max 1.8, 2 watts transmitter?
Thnx for yr time
Regards,
JB
Anything more than about 0.05W is illegal because it will probably interfere with REAL radio stations.
My FM transmitter has a range of 2km to a very sensitive receiver with nothing in between. Another member made it and saw the RF cops (with their antenna on top of their truck) slowly driving down his street the day after he tested it. They were probably looking for me!
I used my FM transmitter for no more than 1 hour.
Here is a powerful FM transmitter from another site: https://www.electronics-lab.com/projects/rf/016/index.html
Btw im already reaching 1.2 km circle diameter, on usb powered transmitter, using 3 stages all 2n3904
Using about 25mA
Im gonna make a new one but this time tune it carefully for 50 ohm impedance, and almost no disturbance, i also got my own free clean fm channel not interfering with other stations.
I have the bf90 and bf91a also but i dont wanna waist these on low frequencies as the can reach ghz, or could the be useful
In reaching 1.8 watt
I do not want to get involved with recommending an illegal radio transmitter. These simple ones do not have accurate crystal frequency control so their frequency will drift which might cause interference. Also their harmonics can interfere with other communications.
I know its illegal, but we all gota build stuff anyways. Tools make da man
Why do you want to interfere with other people's legitimate use of FM broadcasts?
I dont think there is a legitimate use for a home made 2 watt transmiter.
If you use good antennas and a high quality very sensitive receiver (home hi-fi or car radio) then you will have good range without using high power.
But the FM "radio" available at The Dollar Store has terrible sensitivity and selectivity.
Thnx, found this circuit
https://fahriemjeblog.wordpress.com...mitter-88-108-with-independent-vhf-amplifier/
Since the 2n3866 needs about 500mw in, i will build the tx500, and then add the 2n3866 as extra final stage
That should do it right?
I have all the parts, inc rf shield box, rfc, and i will be using an laptop adapter for power supply
Any suggestion?
Yes i know its illegal, but i still want to build, i take all responsebility for whatever may happen.
Please only technical replies
Could i add the 2n3866 as rf amplifier aat antenna output?
And to measure the output watts of a transitor, do i take emitter amps, times power supply?
Or is there a diff formula for that?
Thnx
I know its illegal, but we all gota build stuff anyways. Tools make da man...
Is there anybody else that is not at risk, who can give some pointers
The silence is deafening...
With your attitude, we are just waiting for you to get lost...
I live in an area where there is no one for miles, thats why i want to build this transmitter.
It isnot going to disturb or harm anyone.
I just love to build rf and other stuff
Its just for practice, cause in the end i need to transmitt on 10.184ghz
To understand why, see here where we work on the life ray with John Hutchison, Me, and others
Now we know whats up.
So there is more to this, its not just playing a pirate at FM, its about fukushima
See some more info, so that yall know where im going to, and if you have mad Rf skills you are welcome to join the group to
John has the biggest ray gun of all, and is being tested as we speak, and that one has allot more watts then what im looking for. We are building the smaller version of this
is anybody willing to give some pointers, instead of trolling.
And all of you here are also RF lovers, so just try to think out the box, i know that i may have sounded a bit reckless, but its not wat im doing.
