2 speakers (one as mic other as speaker)
DirectXXX
Im a begineer. I have two 8ohm 0.25 speakers. I want to use one as a mic and other as a speaker. I have a transformer which can supply AC voltage of 4, 8 or
12 volts from room powersupply.
So how can i do this SIMPLY???
Hi DirectXXX,
It is OK to use a speaker as a mic.
You will need an amplifier.
Connect one of your speakers to the amplifier's
input, and the other to the amplifier's output.
Amplifiers run on DC.
Regards, John :)
i know about amplifier. But i want to do some low level. I heared you can use transistor in this case with a higher voltage supply. But i dont know which transistor. and where should i make connection with three pins of transistor.
look up simple audio amplifyers. they can help
This link may help. It is very simple. Although designed for an electret mike, an 8ohm speaker would probably be OK.
