1watt led driver with 12v input
srajesh1268
I want to make a Solar Street light with 6nos of 1Watt LED, But i do not know how to drive the leds. I tried by connecting indivissual resister in series with each LED, But I could not get maximum illumination from LEDs.
Any one can help me regarding this with a low power dissipation circuit?
If the LEDs are not full brightness, then the resistors value is too large; reducing the resistor will increase the brightness.
For a 'low-dissipation circuit', I would suggest connecting all the LEDs in series and powering them with a boost converter regulating for constant current.
I was going to suggest a switching regulator but since you're having problems with a simple resistor, it's probably beyond your current level of ability.
https://www.electro-tech-online.com/threads/led-switching-regulator.41375/
The power supply is 12V and the LEDs probably have a forward voltage of 3.5V (assuming they're white) which limits you to three in series maximum.
