10K I have set it for best, I think.What contrast pot have you used??? Seems as if its either on 0 or 5v..
Why are you adding CRLF to the LCD messages.?
Also you have declared the baselat and baselon as Single variables, how do you expect to get all those characters on one line of 20 characters.?
The message format is also incorrect.
Eric
'test ONLY
baselat = 52.123456
baselon = 1.123456
Lcdcmdout LcdLine1Home
Lcdout "LCD TEST1 ", #baselat, " ", #baselon
Lcdcmdout LcdLine2Home
Lcdout "LCD TEST2 ", #baselat, " ", #baselon
Lcdcmdout LcdLine3Home
Lcdout "LCD TEST3 ", #baselat, " ", #baselon
Lcdcmdout LcdLine4Home
Lcdout "LCD TEST4 ", #baselat, " ", #baselon
EDIT:
This single quote in your original message effectively 'rem's out' the remainder of the message.
T " ', #ba
Hi I,I usually turn it until there is no bars then back until I can just see them.
If the screen hasn't initialized then only line one and line three will have solid bars..
Hi Eric,
I'm still playing with the program, perhaps I can leave that for now. I've simplified it and re posted it.
I'm concentrating on the LCD at the moment. I can get the it to work in the SIM, but not in the circuit.
Thanks, C.
hi,I also tried a minimum program on a separate vero board
I never got to grips with Vladimir's 4 bit interface... The only way I could get it working was to edit the ASM file...The program with LCD work ok in simulation.
Hi I,Next up is OSC settings.... You need to make sure its running correctly.... If this is your first run on real hardware did you turn off simulator delay shortning.... ( I see you did sorry!).... You're brownout is set very low and CCP1 is multiplexed with RC1.... What have you on RC1??
hi C,
That's an image of your PCB layout, we need to see at least the components on the PCB.
I do not see any holes for 15pF caps around the 20mHz xtal holes.???
E
