16f877A - Problems with rs 232
agamemnon
Hi people,
I´m having a problem with a pic 16f877a. I´m conecting to a PC and sending some data (i´ve program using the ccsc compiler). The data receive by the PC is'nt the same data as i´m sending. Example, i send 0x55 and the computer receive 0x2b, for all 0x55 the computer are receiving 0x2b, and so on, for each byte i send, there is one equivalent being received by the computer.
I Have used the intel 8051, this is my first time with pic, so i apreciate any help ;)
-> The conection is 9600, no parity, byte with 8 bits and no parity, one stop bit... The pic is using an 20 Mhz Cristal (but i also have tested with a 4mhz ressonator)
I believe it's with the same settings, at least both sides are configured to work with 9600 bps, no parity, and byte with 8 bits...
I just was'nt able to set the stopbits in PIC, but, even changing it in the computer i could'nt get the right values...
StupidDum said:
No, not inverted.
make sure the setting is identical in both computer and pic
Check the PIC clock setting.
I forgot if the PIC use stop bit by default.
If u dont use handshaking, remember to set that on pc too
It might be inverted... either try to send your serial data in TRUE mode (non-inverted) or don't use the MAX232 (if allowed by microcontroller) and hookup straight.
Using the MAX232 is recommended so I would try the first one first :)
Ivancho
