16F877 question
TKS
hey i'm just seeing a scheme where a 16F877 is hooked up..
and there they don't connect both power/ground lines is that correct..????
tks
strange right../???q
strange right..??
another question..
is a osciliscope the basic functions are they easy to learn.>??
i can buy a Telequipment S51B soow maybe you can advise me..??
TKS
Re: strange right../???q
TKS said:
strange right..??
another question..
TKS
The basic functions of an oscilloscope are fairly easy to use, the more complicated ones can be very difficult, but you rarely use them - and by the time you do need them you will probably be getting more expert at using a scope.
Probably the hardest part though is knowing what to use it for, you need a good idea of what each part of the circuit is supposed to do, and what you would expect to find on a scope at particular points. And when you don't find what you expect, working out why not!.
the scope
the cope i can buy is that rubish or is it enough for a beginner..
the price is 75euro's..
TKS
Re: the scope
TKS
It's an old scope, valve rather than transistor, and only single beam, you can see the circuit diagram here **broken link removed**. But any scope is far better than none, and if it's in good working order it would be very useful - and being a valve scope, it's not as easy to 'kill' as a transistor one 8)
