16f628a RA4 problem
birdman0_o
Active Member
Hey guys, I've been playing around tonight and I've run into a problem with Bit 4 of the A register. It is set as output and I am turning it on high, but it is not turning it on. I can't imagine TOCKI being set, which is what is shared with that pin. I've never had this problem before!
Here is my code...Thanks ahead of time :)
; Author  : Mike Baird
; Program : Template
; Date    :
; Table
;		    					    (f) Left Top = bit5
;		    __   (a) Top    = bit0 	(b) Righ Top = bit1
;		   |__|  (g) Middle = bit6  (e) Left Bot = bit4
;		   |__|  (d) Bottom = bit3	(c) Righ Bot = bit2
;0 = b'00111111'
;1 = b'00000110'
;2 = b'01011011'
;3 = b'01001111'
;4 = b'01011010'  <-
;5 = b'01110011'  <-
;6 = b'01110111'  <-
;7 = b'00101010'  <-
;8 = b'01111111'  <-
;9 = b'01111010'  <-
	List	P=16F628
	#include	"P16F628.INC"
	__config	_PWRTE_ON  & _WDT_OFF & _INTRC_OSC_NOCLKOUT & _BODEN_ON & _LVP_OFF & _CP_OFF & _MCLRE_OFF
;*** Cblock ***
	CBLOCK	0x20
	d1					;
	d2					;
	Number1				;
	Number2				;
	Number3				;
	Number4				;
	ENDC
;*** Defines ***
#Define Bits 	PORTA,0
#Define Clock	PORTA,7
#Define Latch	PORTA,6
;*** Macro ***
HC595 MACRO Var,Var1
	Local Loop		; Local Label
	MOVLW .8		; Transfer 8 bits
  	MOVWF Var1		; Initializing counter
Loop
	RLF Var,f	; Rotate "Var" one place to the left
	BTFSS STATUS,C	; Is carry 1?
	BCF Bits		; If not set data line to 0
	BTFSC STATUS,C	; Is carry 0?
	BSF Bits		; If not set data line to 1
	BSF Clock		; Generate one clock
	BCF Clock		;
	DECFSZ Var1,f	; Has 8 bits been sent?
	GOTO Loop		; If not, repeat
	BSF Latch		; If all 8 bits have been sent, set latch
	BCF Latch
	ENDM
;*** START OF RAM ***
	ORG	0x000			; Start of program vector
	GOTO	Start		;
	ORG	0x004			; Interrupt vector
;	Goto ISR
Start
	MOVLW	0x07		; Turn comparators off and enable pins for I/O
	MOVWF	CMCON		; ^
	CLRF	PORTA		; PortA all low
	CLRF	PORTB		; PortB all low
	BSF	STATUS,RP0		; Bank 1
	MOVLW b'00100000'	;
	MOVWF	TRISA		; PortA all output except MCLR
	CLRF	TRISB		; PortB all output
	BCF	STATUS,RP0		; Bank 0
Main:
	BCF PORTA,4
	BSF PORTA,1
	MOVLW b'00111111'
	MOVWF Number1
	HC595 Number1,Number2
	Call Delay
	BCF PORTA,1
	BSF PORTA,2
	MOVLW b'00000110'
	MOVWF Number1
	Call Delay
	BCF PORTA,2
	BSF PORTA,3
	MOVLW b'01011011'
	MOVWF Number1
	Call Delay
	BCF PORTA,3
	BSF PORTA,4
	MOVLW b'01001111'
	MOVWF Number1
	Call Delay
	GOTO Main
; *** Delay ***
Delay
	MOVLW	d'255'
	MOVWF	d1
	MOVLW	d'255'
	MOVWF	d2
D2
	DECFSZ	d1,F
	GOTO	D2
	DECFSZ	d2,F
	GOTO	D2
	RETURN
	END
; That's all folks!
RA4 is an open drain output. That means it can be used to sink current, but not to source current.
Another thing to remember is that when configured as an input, RA4 is a Schmitt Trigger input.
