12v battery, 18v magic
TinkerPhil
I bought an 18v mower with no battery.
Maybe naively I thought I'd be able to run it off a 12V battery charger but no... Nothing!
So I checked all the circuits and they're good weirdly though the 12v input from the charger measured at 18v as if the circuit was so eager for 18v it was forcing 18v back to the source.
When I took the source away the 18v slowly dwindled down
I'm guessing there's some sort of boost circuit in the mower that needs a healthy 18v source to actually power the mower
Now I carelessly ran 12v the wrong way into the circuit - will I have fried it?
so here's a picture of the circuit in the mower
Can anyone give any quidance?
An 18 V battery mower will almost always cut off at some voltage to protect the battery, and I would expect that voltage to be somewhere around 14 to 16 V.
A 12 V battery charger will often put out 18 V with no load. Chargers designed to connect directly to a battery are unlikely to be suitable to run anything directly.
The current that the mower will take, especially when starting, will be quite big and you would need a very large power supply to run it.
Connecting a power supply backwards may have damaged something but without a lot more information it's hard to know for sure.
Thanks for the reply
It was actually a car battery I wired in the wrong way round - doh!
I suspect it is fried
but I will try to wire it up with an 18v source and see where that takes me
The proper battery will be Li-Ion (and almost certainly 18650's) - and will be 5 in series (or more than one set of five, in parallel for higher capacity) - personally I'd call it a 21V battery pack, as when fully charged it will read 21V (5 x 4.2V). The 18V figure is when they are flat, 5 x 3.6V = 18V.
