100KHZ Sawtooth Generator crcuit?
imgemini
hi friends
i am looking for 100Khz Sawtooth Generator criuit for my college Lab project ....
niose Generator also works :arrow:
An ICL8038 function generator IC may do.
Try this link:
Have you ever heared of Google?
Do you do anything for yourself?
I gave you a reference for the 8038 in my original post.
Try this for the XR2206.
https://www.elexs.de/sinus1.htm
100kHz is toward the high end of the ICL8038's capability, but it's also obsolete. You may still be able to find some.
I think the OP needs to put a little more effort into his own research, though.
j.
Haven't we been through this exercise before?
Do you need A, B, or C? How many volts peak-to-peak?
hi
A will be great..........
should be 100Mhz or more but DV offset the output should be 17V - 20V
The XR2206 circuit looks to be fairly easy to build and will probably make a nice piece of bench equipment. I ordered a couple of those chips and intend to build one pretty soon. Thanks for the info.
imgenini wrote
should be 100Mhz or
I think you meant 100Khz
I think if you generate a square wave at 100Khz and then feed it to an op amp integrater you will have the wave form that you need.
Run a astable 555 timer at 100kHz (it is very near its limit) and you will get the sawtooth waveform of the timing capacitor. You can use a opamp buffer/amplifier to prevent loading of this signal.
If you have to make your own, the basic building blocks are: Constant current source, flip-flop, 2 comparators, a capacitor, and resistor.
Charge the cap from the current source, detect the upper voltage trip with the comparator, flip the flip-flop and discharge the cap through a resistor while detecting the lower voltage trip. Flip the flip-flop and start the charge cycle again..
You have now effectively made your own 555!
At 100kHz you will need a fairly fast comparator like the LM311
Probably the biggest difference between the 555 and the 8038 is that the 8038's capacitor is charged by a current source, while the 555's is not. So the 555 will not put out a real sawtooth, but may be close enough.
j.
If a "true" sawtooth is not that important, a simple uni-junction oscillator may also do.
I would say only A is a sawtooth. B and C are ramps. But I wouldn't be contentious about it.
j.
Well, John, then I guess I have to get contentious. :D
According to this site, waveform A is a triangle wave, and the other two are sawtooths (sawteeth?). I gotta say they all look like triangles to me - maybe A shoulda been called an isosceles triangle wave. I can see why the other two are called sawtooth waves.
