100 watt led driving with 150w dc to dc converter. Help needed
The LM338T current regulator will not work if you cannot supply it wit at least 3 volts more than the LED requires at it's rated current. If the boost regulator is rated at 35 volts maximum output I would not use it so close to it's maximum ratings.
Les.
so i cant a 100 watt power from it??? even if i dont use the lm 338t??
