1 kHz pulse generator using NE555
deva_raj24
--> This is my exact task given. To design a oscillator circuit that produces a 1kHz clock signal using a NE555 Timer IC.
There has to be an output on the oscillator circuit such that the output can be connected to another board. a RED LED should also light when power is being supplied to the board .
- Design document showing any design and calculations.
- schematic capture of design
- PCB Layout
SPECIFICATIONS
power - a tester shall be powered by a 9V battery. a batery clip shall be used to connect the battery to the PCB board.
voltage regulation - you might need to regulate your supply to 5V
provide a pin header for common Ground connection
- If u can help me , plz reply! thank you!!!!!
There're a lot of information about 555 timer, just google it. The datasheet even provides the schematic.
