I've soldered some 0.1mm enamel wire leads to a few 0805 size SMD leds.
They are white and rated the same as a standard white led - around 3.2 volts and around 20-25ma max current.
They work as expected, although above 9ma they start to get quite hot. At 13ma, touching them on my lip they feel quite toasty.
Is this to be expected as they are attached to 0.1mm wire instead of to the larger mass of a PCB ?
An advice appreciated.
