Z80 MONITOR
Andrei22
Hello,i am new here and i have a question regarding the monitor display on z80 cpu,what can i do so that it will display scrolling from right to left the message "Welcome to UP!",because i tried with stack but failed and also i don't have a z80 emulator and at college we use some old fashioned z80 cpu and from the start of the semester i learned so little because our teacher doens't cares about us and never explains,so if someone can help me with this,i will be gratefull.
I need to know your hardware.... Is the z80 connected to a screen serially.... Is the screen a terminal?
Have you picture....
OshonSoft have a z80 emulator... I use it quite a bit as I mess with zx spectrum's a lot!!
I don't really know the hardware,because is a big box ,and we never used them because they are broke.
Microprofessor MPF1-B,display consists of six 7-segment display(plus decimal point ) .has a total of 8 leds.
ORG 1800H
LD A,"!"
LD B,"P"
LD K,"U"
LD D,"O"
LD E,"T"
LD F,"E"
LD G,"M"
LD H,"O"
LD I,"C"
LD J,"L"
LD K,"E"
LD L,"W"
PUSH A
PUSH B
PUSH K
PUSH D
PUSH E
PUSH F
PUSH G
PUSH H
PUSH I
PUSH J
PUSH K
PUSH L
CALL LOOP
how can i do so that it will show each letter on the display....
If the display is only 7 segments, you can only display 0 thru 9, A,B,C,D,E,F and some other lower case alpha characters.
E
Oooh! Its a little harder than that!!!
Here is a simple guessing game... Notice how EVERYTHING has to be written...
You have to write functions.. The MPF1 is empty until you load a program..
;  guess.asm
;  Number guessing game
;  Author : San Bergmans
;  Source : www.sbprojects.com
;  Date  : 25-1-2006
;  Human and computer will take turns to guess each other's secret number
;  in the range from 0 to 1023 (inclusive).
  .CR  Z80  Yeah! We're programming the Z80!
  .OR  01800H  RAM starts here, so are we
  .TF  guess.hex,HEX  Create a plain hex dump file
;  Constants
PLUS  .EQ  010H  + key  Guess higher
MINUS  .EQ  011H  - key  Guess lower
GO  .EQ  012H  GO key  Accept input
DATA  .EQ  014H  DATA key  Give up, MPF next
DEL  .EQ  017H  DEL key  Clear input
PC  .EQ  018H  PC key  Cheat
REG  .EQ  01BH  REG key  Restart program
SA  .EQ  00001000B  Segment A
SB  .EQ  00010000B  Segment B
SC  .EQ  00100000B  Segment C
SD  .EQ  10000000B  Segment D
SE  .EQ  00000001B  Segment E
SF  .EQ  00000100B  Segment F
SG  .EQ  00000010B  Segment G
DP  .EQ  01000000B  Decimal point
;  Monitor routines
SCAN  .EQ  005FEH  Scan display until a key pressed
SCAN1  .EQ  00624H  Scan display once
HEX7  .EQ  00689H  Convert digit to 7-segement
HEX7SG  .EQ  00678H  Convert 2 hex digits to 7-segment
TONE  .EQ  005E4H  Generate tone (C=freq, HL=cycles)
TONE1K  .EQ  005DEH  Sound a 1kHz tone during (HL)
;  GUESS
;  Start of the program.
;  Now it's your turn to guess the secret number.
;  Enter your guess and press GO to see whether you should guess higher
;  (indicated by an H) or lower (indicated by an L)
GUESS  LD  A,R  Randomize seed a little
  LD  (SEED),A
AGAIN  CALL  RANDOM  Calculate a random secret number
  LD  IX,.TEXT  Show "GUESS" until a key
  XOR  A,A  Clear input value
  LD  (INPUT),A
  LD  (INPUT+1),A
  LD  (DSP_BFFR),A  Clear right most display
  LD  (COUNTER),A  Clear try counter
.LOOP  ;  Main loop during human turn
  CALL  SCAN  Show display until key pressed
  CP  A,10  Was it a digit key?
  JR  NC,.NODIGIT  No!
  CALL  DEC2BIN  Add digit to input value
  JR  .LOOP  Show intermediate result!
.NODIGIT  CP  A,REG  Was it the REG key?
  JR  Z,GUESS  Yes! Restart the program
  CP  A,DEL  Was it the DEL key?
  JR  NZ,.NOTDEL  No! Don't clear value
  XOR  A,A  Clear the input value
  LD  (INPUT),A
  LD  (INPUT+1),A
  CALL  SHOW_VAL  Show this value
  JR  .LOOP  And wait for input again!
.NOTDEL  CP  A,PC  Was it the PC key?
  JR  NZ,.NOTPC  Nope!
  CALL  PEEK  Give us a peek at the secret!
  JR  .LOOP  And continue where we left off!
.NOTPC  CP  A,GO  Was it the GO key?
  JR  NZ,.NOTGO  Nope!
  LD  HL,COUNTER  Increment try counter
  INC  (HL)
  JR  NZ,.SKIP  No overflow!
  DEC  (HL)  Stop at ridiculous 255 tries
.SKIP  CALL  COMPARE  Compare input value to target
  LD  A,B  Guessed the number?
  AND  A,A  (test flags)
  JR  NZ,.LOOP  Nope!
  JR  CORRECT  Yes!
.NOTGO  CP  A,DATA  DATA key?
  JR  NZ,.LOOP  Nope! Ignore the key then
  JP  COMPUTER  We give up, let the MPF try
.TEXT  .DA  #0
  .DA  #SA+SC+SD+SF+SG  S
  .DA  #SA+SD+SE+SF+SG  E
  .DA  #SB+SC+SD+SE+SF  U
  .DA  #SA+SC+SD+SE+SF  G
;  CORRECT
;  We've guess the number correctly. Show YES and the number of tries now
CORRECT  LD  C,68  Sound short beep
  LD  HL,47  (same as default system beep)
  CALL  TONE  Sound beep
  LD  A,(COUNTER)  Convert number of tries to
  CP  A,100  decimal & 7-segment, limited
  JR  C,.SKIP  to 99
  LD  A,99
.SKIP  LD  (INPUT),A
  XOR  A,A  Counter is only 1 byte, so clear
  LD  (INPUT+1),A  MSB
  CALL  SHOW_VAL
  LD  A,SD+SE+SF+SG  Show "t" behind number of tries
  LD  (HL),A
  LD  HL,DSP_BFFR+5  Show "YES." in front of counter
  LD  A,SB+SC+SD+SF+SG
  LD  (HL),A
  DEC  HL
  LD  A,SA+SD+SE+SF+SG
  LD  (HL),A
  DEC  HL
  LD  A,SA+SC+SD+SF+SG+DP
  LD  (HL),A
  CALL  SCAN  Show this until a key is pressed
  JP  COMPUTER  Now it's the MPF's turn to guess
;  DEC2BIN
;  A new digit was entered. Multiply previous input value by 10, then add
;  the new digit to form the updated input value.
DEC2BIN  LD  B,A  Save new digit
  LD  A,(INPUT)  Get previous value
  LD  L,A
  LD  A,(INPUT+1)
  LD  H,A
  ADD  HL,HL  Multiply input value by 10
  JR  C,.OVERFLOW  Number is too big!
  LD  D,H  (x * 10 = x * 2 + x * 8)
  LD  E,L
  ADD  HL,HL
  JR  C,.OVERFLOW
  ADD  HL,HL
  JR  C,.OVERFLOW
  ADD  HL,DE
  JR  C,.OVERFLOW
  LD  A,B  Add new input digit to it
  ADD  A,L
  LD  (INPUT),A
  LD  A,0
  ADC  A,H
  LD  (INPUT+1),A
  JP  NC,SHOW_VAL  Digit added! Show current value
.OVERFLOW  LD  IX,.ERROR  Show ERROR
  LD  (INPUT),A
  LD  (INPUT+1),A
  RET
.ERROR  .DA  #0
  .DA  #SE+SG  r
  .DA  #SC+SD+SE+SG  o
  .DA  #SE+SG  r
  .DA  #SE+SG  r
;  SHOW_VAL
;  Convert the value in INPUT to a 5 digit 7-segment number
;  Conversion is done by repeatedly subtracting 10000 from the initial
;  number for as long as it is possible. The number of successful
;  subtractions is the most significant decimal digit. Then 1000 is
;  repeatedly subtracted, etc, etc. Until finally a digit from 0 to 9
;  remains, which is the least significant digit.
;  At the same time we suppress leading zeroes, which makes it all look
;  much nicer.
SHOW_VAL  LD  IX,DSP_BFFR+5  Use display buffer for result
  LD  IY,.DECADES  Point to the decades table
  LD  A,(INPUT)  Get value to be converted
  LD  L,A
  LD  A,(INPUT+1)
  LD  H,A
.LOOP  LD  A,(IY)  Get current decade
  LD  E,A
  INC  IY
  LD  A,(IY)
  LD  D,A
  INC  IY  IY now points to next decade
  OR  A,E  Was end of table reached?
  JR  Z,.END  Yes!
  LD  B,0  Clear decade value
.COUNT  LD  A,L  Try to subtract decade from
  SUB  A,E  value
  LD  C,A  Temporarily save result
  LD  A,H
  SBC  A,D
  JR  C,.EXIT  Didn't go!
  LD  H,A  Save new intermediate result
  LD  L,C
  INC  B  Increment decade counter
  JR  .COUNT  Count as long as it goes!
.EXIT  LD  A,B  Save this digit's value
  LD  (IX),A
  DEC  IX  Point to next digit
  JR  .LOOP
.END  LD  A,L  Last decade is in L now
  LD  (IX),A
  LD  IX,DSP_BFFR  Reload display buffer pointer!
  LD  HL,DSP_BFFR+5  Convert the 5 decimal digits to
  LD  B,4  7-segment patterns (start left)
  LD  C,0  Leading 0's while this is 0
.7LOOP  LD  A,(HL)  Get a decimal digit
  OR  A,C  Leading 0?
  JR  Z,.SKIP  Yes! Skip this one
  LD  C,A  Set leading 0 flag now
  LD  A,(HL)
  CALL  HEX7  Convert digit to 7-segments
  LD  (HL),A  and store it in display buffer
.SKIP  DEC  HL  Do next digit (to the right)
  DJNZ  .7LOOP  Do 4 of the 5 digits this way
  LD  A,(HL)  Always display last digit,
  CALL  HEX7  even if the rest were all zeroes
  LD  (HL),A
  DEC  HL  Blank last digit
  LD  (HL),0
  RET
.DECADES  .DA  10000
  .DA  1000
  .DA  100
  .DA  10
  .DA  0  Indicating end of conversion
;  RANDOM
;  Generate a pseudo random number between 0 and 1023
RANDOM  LD  A,(SEED)  Get previous SEED value
  LD  L,A
  LD  A,(SEED+1)
  LD  H,A
  LD  D,L  Calculate pseudo random number
  LD  E,6
  SRL  D
  RR  E
  ADD  HL,DE
  LD  A,L  Save new SEED value
  LD  (SEED),A
  LD  A,H
  LD  (SEED+1),A
  LD  (HL),A
  LD  A,L  Save secret number now
  LD  (SECRET),A
  LD  A,H
  AND  A,00000011B  (limit number to 10 bits)
  LD  (SECRET+1),A
  RET
;  PEEK
;  The user pressed the PC key to cheat! Show the secret number for as
;  long the PC key is held down.
PEEK  LD  HL,INPUT  Save current input value
  LD  E,(HL)
  INC  HL
  LD  D,(HL)
  PUSH  DE
  LD  A,(SECRET+1)  Copy secret to input in order to
  LD  (HL),A  be displayed
  DEC  HL
  LD  A,(SECRET)
  LD  (HL),A
  CALL  SHOW_VAL  Convert this value to 7-segments
  DEC  HL  Save right most display and then
  LD  A,(HL)  clear it
  PUSH  AF
  LD  (HL),0
.LOOP  CALL  SCAN1  Display this value until the
  JR  NC,.LOOP  key is released!
  POP  AF  Restore right most display
  LD  (DSP_BFFR),A
  POP  DE  Restore input value
  LD  HL,INPUT
  LD  (HL),E
  INC  HL
  LD  (HL),D
  RET
;  COMPARE
;  Compare the new input to the secret number. If the input is lower than
;  the secret number an H is displayed behind the input value. If the
;  input value is higher than the secret value an L is displayed. If
;  the input value matches the secret number register B will be 0 so that
;  main routine can take appropriate action.
COMPARE  LD  HL,INPUT  Get input value
  LD  E,(HL)
  INC  HL
  LD  D,(HL)
  LD  HL,SECRET  Compare it to the secret value
  LD  A,(HL)
  SUB  A,E
  LD  B,A
  INC  HL
  LD  A,(HL)
  SBC  A,D
  JR  C,.LOWER  We're too high!
  OR  A,B  See if we guessed correctly
  LD  B,A  (Use B as flag upon return)
  RET  Z  Got it!
.HIGHER  LD  A,SB+SC+SE+SF+SG Display an H
  JR  .DONE
.LOWER  LD  A,SD+SE+SF  Display an L
.DONE  LD  (DSP_BFFR),A
  XOR  A,A  Clear input value for next guess
  LD  (INPUT),A
  LD  (INPUT+1),A
  RET
;  COMPUTER
;  Now it's the computer's turn to guess a secret number.
;  The computer uses successive approximation to guess the secret number.
;  Here's how it works:
;  Initial guess  1000000000  Higher (leave last bit set)
;  2nd guess  1100000000  Lower  (clear last bit)
;  3rd guess  1010000000  Higher (leave last bit set)
;  4th guess  1011000000  Lower  (clear last bit)
;  5th guess  1010100000  Lower  (clear last bit)
;  6th guess  1010010000  Higher (leave last bit set)
;  7th guess  1010011000  Higher (leave last bit set)
;  8th guess  1010011100  Lower  (clear last bit)
;  9th guess  1010011010  Higher (leave last bit set)
;  10th guess  1010011011  This must be the secret number!
;  You see that a mask bit shifts to the right after each guess. This bit
;  remains set if we have to guess higher, or is cleared if we have to
;  guess lower. Then it's shifted again, added to the previous result to
;  form the new guess.
COMPUTER  LD  HL,MASK  Set initial mask for successive
  XOR  A,A  approximation
  LD  (HL),A
  INC  HL
  LD  (HL),00000010B
  LD  HL,INPUT  Set initial accumulation value
  LD  (HL),A  (which is in fact our first
  INC  HL  guess)
  LD  (HL),00000010B
  INC  A  Set guess counter to 1 because
  LD  (COUNTER),A  we'll start right away
.LOOP  CALL  SHOW_VAL  Convert value to 7-segments
  LD  (HL),SA+SB+SE+SG  Display "?"
  CALL  SCAN  Show this guess
  CP  A,PLUS  Should we guess higher?
  JR  Z,.HIGHER  Yes! Next guess should be higher
  CP  A,MINUS  Should we guess lower?
  JR  Z,.LOWER  Yes! Next guess must be lower
  CP  A,DATA  DATA key?
  JR  Z,COMPUTER  Yes! Restart computer's turn
  CP  A,REG  REG key?
  JP  Z,GUESS  Restart entire game (user's turn)
  CP  A,GO  GO key?
  JR  Z,.RIGHT  Yes! Guessed right, show tries
  JR  .LOOP  Ignore all other keys!
.HIGHER  CALL  SHIFT_MASK  Shift approximation mask right
  CALL  .ADDMASK  Add new mask
  JR  .LOOP  Show next try!
.LOWER  LD  HL,INPUT  Undo last guess
  LD  A,(MASK)
  XOR  A,(HL)
  LD  (HL),A
  INC  HL
  LD  A,(MASK+1)
  XOR  A,(HL)
  LD  (HL),A
  JR  C,.END  Run out of mask bits!
.OK  CALL  .ADDMASK  Add new mask
  JR  .LOOP  Take next guess!
.END  LD  HL,INPUT+1  Last bit was not supposed to
  LD  A,(HL)  be cleared unless the guess
  DEC  HL  is 0
  OR  A,(HL)
  JR  Z,.OK  Was 0 indeed!
  INC  (HL)  Set b0 of the guess again
  JR  .OK
.RIGHT  LD  A,(COUNTER)  Show number of tries
  LD  (INPUT),A
  XOR  A,A
  LD  (INPUT+1),A
  LD  (HL),SD+SE+SF+SG  Display "t"
  CALL  SCAN  Show this until next key press
  JP  GUESS  Then start all over again
.ADDMASK  LD  HL,INPUT  Combine accumulation value with
  LD  A,(MASK)  the new mask
  LD  B,A
  OR  A,(HL)
  LD  (HL),A
  INC  HL
  LD  A,(MASK+1)
  LD  C,A
  OR  A,(HL)
  LD  (HL),A
  LD  A,B  Was MASK 0?
  OR  A,C
  RET  Z  Yes! Don't increment counter!
  LD  HL,COUNTER  Increment guess counter
  INC  (HL)
  RET
;  SHIFT_MASK
;  Simple routine to right shift a 16-bit number
SHIFT_MASK  LD  HL,MASK+1  Shift mask 1 bit to the right
  SRL  (HL)  starting with MSB of course
  DEC  HL
  RR  (HL)
  RET
;  RAM locations
;  These locations are not included in the program code. This would allow
;  the program to be burned in ROM. No code is generated here, only the
;  labels get their appropriate values.
  .OR  01D00H
  .DU  Don't generate any code
INPUT  .BS  2  Input word value
SECRET  .BS  2  Value to guess
SEED  .BS  2  Random number seed
MASK  .BS  2  Successive approximation mask
COUNTER  .BS  1  Try counter
DSP_BFFR  .BS  6  6 Bytes display buffer
  .ED
  .LI  OFF
Its quite the learning curve
To display digits, you need to examine this code and look how its been done.. Look at the function "ShowVal"
How can this help me if i want to make a simple program to show me on display monitor a scrolling message?
hi Andrei,
You cannot display the full alphabet of characters on a 7 segment display.
So "Welcome to UP is not possible.
E
This is an image of a 7 segment display, show me how you can display a 'W' or an 'M' on it.??
Could be that each one is having different a type in mind (I recall that OLD professor that I couldn't afford when I wanted it). Surprised that is still being used.
The union jack type has 14 segmnents.
I tried 2 programs :
1:
ORG 1800H
LD A,1 ;
LD BC,STRING ; bc points to the string data in memory
LOOP: ;
LD A,(BC) ; Incarca A cu bitul din locatia BC
CP 0 ; Compara A cu 0(end of STRING data)
JR Z,EXIT ; Daca este egal cu 0 atunci sare la EXIT
RST $10 ; Afiseaza A pe ecran
INC BC ; Incrementeaza BC cu 1 pentru a sari la urmatorul bit
JR LOOP ; Sare la LOOP sa faca din nou
EXIT
RET ; Ne intoarce la basic
STRING: ;
DEFB "Welcome to UP!"
DEFB 13,0 ; 13 este o noua linie si 0 inseamna sfarsit de data
and 2:
ORG 1800H
LD A,1
LD BC,MESAJ
LOOP: LD A,(BC)
CP 0
JR Z,EXIT
RST %10
INC BC
JR LOOP
EXIT
RET
MESAJ: DEFB 00111110B; U1 W
DEFB 00111110B; U2
DEFB 01111001B; E
DEFB 00111000B; L
DEFB 00111001B; C
DEFB 00111111B; O
DEFB 00110111B; M1 M
DEFB 00110111B; M2
DEFB 01111001B; E
DEFB 00000111B; T1 T
DEFB 00110001B; T2
DEFB 00111111B; 0
DEFB 00111110B; U
DEFB 01110011B; P
Andrei
I am sure you have seen my post (#13) preceding yours above (#14).
Could you be kind enough to, at least, aknowledge it?
I know about that,it is the 7 segment display
Good.
Wile I forgot all about the Z80 Assembler, I can see that you still keep trying to show "welcome" thorugh them. Sorry but it makes no sense to me.
What does this instruction do?
Allen
The Z80 works a lot with reset vectors... Rst10 is software call that runs certain code.. Usually A is loaded with the call number... In this case Rst $10 is a print to display call and A contains the character...
BUT!! this system will not take two characters as required... the second part is wrong.. RST %10....
