    Dismiss Notice
XTAL Problem in PIC 16F877A
Discussion in 'Microcontrollers' started by Hesam Kamalan, Jul 16, 2006.
  1. Hesam Kamalan
    Hesam Kamalan New Member
    Oct 15, 2005
    130
    0
    Hi
    I have a problem with 16f877a. I build a PCB for this PIC component. After programming (for example I wrote blinking LED), LED is off, but when I touch XTAL, LED turned on continuously. I change XTAL several times but outcome was the same. My XTAL is 20MHz and Caps 33pF.
  2. rtamas
    rtamas New Member
    Jul 11, 2006
    2
    0
    That's why the XTAL's body must be soldered to GND and ofcourse the PCB's GND must be rastered.I think this method will solve your problem.
    P.S. You can use oscillators insted of XTAL.They are more stabile.
  3. mramos1
    mramos1 Active Member
    Sep 15, 2005
    2,403
    9
    Boynton Beach, Florida USA
    Can you send the start of your code (where you define PIC, OSC, etc)?
    Do you have any 20pf caps? Maybe try swapping the 33 for something smaller.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. zkt_PiratesDen
    zkt_PiratesDen New Member
    Jun 29, 2006
    68
    0
    Are you sure about this ?
  6. Hesam Kamalan
    Oct 15, 2005
    130
    0
    Thank you very much for your Helps and advertises, my code is written as follows:
    PROCESSOR 16F877A
    #INCLUDE "P16F877A.inc"
    #INCLUDE "HESAM.INC"
    __CONFIG _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC
    CBLOCK 0X20
    HICNT
    LOCNT
    LOOPCNT
    ENDC
    ORG 0X00
    BANK3
    MOVLW 0X02
    MOVWF ADCON1
    BANK1
    MOVLW 0X00
    MOVWF TRISE
    BANK0
    MOVLW 0X00
    MOVWF PORTE
    MAIN:
    MOVLW 0X01
    MOVWF PORTE
    PAUSEMS 500
    MOVLW 0X02
    MOVWF PORTE
    PAUSEMS 500
    MOVLW 0X04
    MOVWF PORTE
    PAUSEMS 500
    GOTO MAIN
    END
  7. mister_e
    mister_e New Member
    Jul 14, 2006
    350
    2
    Montreal, Canada
    1. you must use HS_OSC
    2. Be sure you connect all VSS lines and all VDD line
    3.as suggested, try something in between 15-33pF
    4. be sure your MCLR pin is tied to VDD via resistor
    5. Be sure you'd place capacitor (0.1uF) as close as possible of your PIC. For this one, i suggest 2, one on each side as you have VDD and VSS on both side of it.
  8. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,199
    640
    Derbyshire, UK
    As suggested, use smaller capacitors, check my tutorial hardware at http://www.winpicprog.co.uk/pic_tutorial_main3_board.htm which uses 12pF ones. You don't mention how you're building it?, but you need as short a leads as possible, both to the crystal and from the capacitors to 0V.
    As also suggested, it's important that you select HS_OSC, which is for high speed crystals.
  9. Mike - K8LH
    Mike - K8LH Well-Known Member
    Jan 22, 2005
    3,637
    109
    Michigan, USA
    Your problem may be that you have not disabled LVP in the configuration fuses and you have left the PGM pin 'floating'. I've seen these symptoms described many times and easily corrected by reprogramming the PIC with the LVP option in the config' fuses turned off.
    Regards, Mike
Share This Page
