Will recording like this hurt my laptop?
joecool85
I have a 12" Apple PowerBook. It doesn't have a mic jack, only a line in. If you use a mic straight to that you get basically no sound (duh). So, I've been using my little gem 1/2watt guitar amp as a preamp. I plug the mic into that, and then use the speaker out on that into my laptop. I monitor the levels on my laptop making sure I'm not peaking too much.
Here is the schematic for the little gem:
No, it should be no problem, the voltage output of the amp won't be very high anyway - if you really want to feel safe though, feed it via a resistor to the laptop.
What would be a safe voltage to run into the laptop? I've heard lineout voltages can vary from .5volts to 2 is that right?
Also, to test the voltage, can I just hook the positive of my multimeter to the + on the speaker out, and - to ground?
That range sounds about right!. Your laptop should handle those no problem, a tiny amp like that dosn't have enough ouput to damage anything. If you like, insert a 10kohm resistor in the signal lead.
No, you need an AC millivoltmeter or a scope.
Ha, I'm fine. Here is what I found out for my laptop:
maximum input signal amplitude 2 Vrms (5.65 Vpp), +8 dbu peak
