    Dismiss Notice
why two ground pins?
Discussion in '8051/8951' started by Rohitchampion, Feb 26, 2014.
  1. Rohitchampion
    Rohitchampion New Member
    Apr 12, 2013
    15
    0
    India
    If you see 8086 microprocessor pin diagram, there are two GROUND pins, PIN1 and PIN20.
    Can anybody explain why two ground pins are used on 8086?
    I searched on google but all are giving different answers so I am posting here.
  2. JimB
    JimB Super Moderator Most Helpful Member
    Sep 11, 2004
    6,324
    585
    Peterhead, Scotland
    If you look at the PIC 16F887, you will see that that has two ground and two supply pins.
    I can think of two possible reasons:
    Two connections makes for a lower impedance connection.
    One connection for each of two different parts of the chip, makes life easier for the guy designing the silicon.
  3. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,908
    1,094
    I can think of better reasons for the PIC:
    Analog ground, digital ground
    The pin for the ratiometric reference ground.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. NorthGuy
    NorthGuy Well-Known Member
    Sep 8, 2013
    1,218
    206
    Northern Canada
    And then datasheet suggests that all ground pins have to be connected, which, if followed, makes PCB design harder. How come the guy designing the silicon is more important than the PCB guy?
  6. KeepItSimpleStupid
    Oct 30, 2010
    9,908
    1,094
    Because in silicon, its harder. No layers. Wire bonds to anywhere on the chip. No insulated wire though.
    I did some manual ultrasonic gold wire bonds before.
  7. JimB
    Sep 11, 2004
    6,324
    585
    Peterhead, Scotland
    A reasonable supposition, however, the PIC datasheet makes no mention (as far as I can see) of separate analogue and digital grounds.
    Northguy said:
    I did not intend to imply that anyone was more important than anyone else.
    Maybe it is a good idea to provide supplies to both sides of the chip, rather than having the supplies for one side flow through the other side.
    I don't know, just supposition* on my part.
    * Supposition = A guess that has been to university.
  8. tronitech
    tronitech Member
    Feb 26, 2012
    188
    14
    UK
    I think you're right JimB. It's probably down to distributing clean power "across" the chip. Look at something like the i7 900 series processors, there are in the region of 200 of each supply and ground pins.
  9. atferrari
    atferrari Well-Known Member
    Oct 8, 2003
    2,810
    121
    Buenos Aires - Argentina
    :stop: An educated guess in short?
  10. Rohitchampion
    Apr 12, 2013
    15
    0
    India
    Thanks JimB
    And yeah there are no separate analog and digital grounds.
  11. atferrari
    Oct 8, 2003
    2,810
    121
    I stopped counting at 220. WOW!
  12. Little Ghostman
    Little Ghostman Well-Known Member Most Helpful Member
    Jan 7, 2011
    3,702
    426
    SCOTLAND
    some pics have analogue and digital supplies! I forget the naming convention but for example the ADC's on some pics have there own supply pin's, even if you use the internal ref etc you still have to power the ADC pins
  13. rc3po
    rc3po Banned
    Mar 10, 2014
    159
    5
    Texas, USA
    Thanks JimB. I'm new to uControllers and I just assumed that the multiple Power & Ground pins were to allow the Chips to carry more current. So I guess I was wrong.
  14. Little Ghostman
    Jan 7, 2011
    3,702
    426
    SCOTLAND
    In some ways your right, if the pic had to internally connect from one side to the other, then surely the current available would drop? Not too sure now Ive said it! to me what goes on inside is the pics business unless it smokes! :D. The bit that annoys me though is they tend to cross the VDD and GND pins on each side! they never seem to be opposite.
  15. JimB
    Sep 11, 2004
    6,324
    585
    Peterhead, Scotland
    Just to keep you on your toes!
    Prevents complacency.:D
  16. rc3po
    rc3po Banned
    Mar 10, 2014
    159
    5
    Texas, USA
    I'm still reading books and learning how to use my new Arduino so I haven't looked into the Chips internal structure.
    Having more Pow/ Grd pins may also help keep the Chip cooler instead of trying to send all of the current through 2 pins. I usually get yelled at around here for using common sense. Perhaps I'm a glutton for punishment?:D
Share This Page
