when to tie MCLR to VDD?
I did find them there, I am just looking for a full description of what each does, cause the spec sheet (at least for the 12f683) does not list them, as they are for the IDE and not the PIC.
I did find some info in the "Memory Programming Specification" sheets that get into the settings.
I designed the pcb with a jumper for the 10k so I can go either method now. Is there a specific date that they changed the terminology so that I can be sure? Then I just gotta find the date the PIC was released, I hope.
Doesn't matter when the PIC was released, PIC's don't have any part of the assembly process - it's all just down to the include file and what it says in there.
I see now. All I had to do was change the hex to binary to see what was happening. I never do things the easy way the first time lol.
Don't! The purpose of the config labels is to simplify the device configuration! :)
I've merged some information from the include file and the datasheet of the PIC12F683:
;       Configuration Bits
_FCMEN_ON                    ;Fail-Safe Clock Monitor is enabled
_FCMEN_OFF                   ;Fail-Safe Clock Monitor is disabled
_IESO_ON                     ;Internal External Switchover mode is enabled
_IESO_OFF                    ;Internal External Switchover mode is disabled
_BOD_ON                      ;BOR enabled
_BOD_OFF                     ;BOR disabled
_CPD_ON                      ;Data memory code protection is enabled
_CPD_OFF                     ;Data memory code protection is disabled
_CP_ON                       ;Program memory code protection is enabled
_CP_OFF                      ;Program memory code protection is disabled
_MCLRE_ON                    ;GP3/MCLR pin function is MCLR
_MCLRE_OFF                   ;GP3/MCLR pin function is digital input, MCLR internally tied to VDD
_PWRTE_OFF                   ;PWRT (Power-up timer) disabled
_PWRTE_ON                    ;PWRT enabled
_WDT_ON                      ;WDT enabled
_WDT_OFF                     ;WDT disabled and can be enabled by SWDTEN bit of the WDTCON register
_LP_OSC                      ;LP oscillator: Low-power crystal on GP4/OSC2/CLKOUT and GP5/OSC1/CLKIN
_XT_OSC                      ;XT oscillator: Crystal/resonator on GP4 and GP5
_HS_OSC                      ;HS oscillator: High-speed crystal/resonator on GP4 and GP5
_INTOSCIO                    ;INTOSCIO oscillator: I/O function on GP4 pin, I/O function on GP5
_INTOSC                      ;INTOSC oscillator: CLKOUT function on GP4 pin, I/O function on GP5
I just meant that I could look at what is being set/cleared with each config setting, I am still using the CONFIG commands just as they are. Thanks for the info though, saves a lot of time scratching my head.
