What's wrong with this code?
Wbdsgnr
I have got a PIR sensor, I amplified it, and now I want to use the comparator inside the 16f88. The reference signal is 5 volt with a variable resistance. Somehow it doesn't work, when lowering the reference voltage PORTB still gives a high output.. But maybe I'm just making a very stupid mistake?
		PROCESSOR 16F88
		#include "p16f88.inc"
		__config	0x1F04
		ORG			0x00
		goto			Main
		ORG			0x04
		goto			INR
Main		banksel		TRISA
		movlw		b'11100111'
		movwf		TRISA
		clrf			TRISB
		movwf		TRISB
		banksel		PORTB
		movlw		b'11111111'
		movwf		PORTB
		banksel		CMCON
		movlw 		b'00000101'
		movwf		CMCON
		banksel		PIE2
		bsf			PIE2,CMIE
		banksel		INTCON
		bsf			INTCON,PEIE
		bsf			INTCON,GIE
INR
		banksel		PORTB
		movlw		b'00000000'
		goto 			INR
		RETFIE
End
      PROCESSOR 16F88
      __config   0x1F04
      ORG         0x00
      goto         Main
      ORG         0x04
      goto         INR
Main      banksel      TRISA
      movlw      b'11100111'
      movwf      TRISA
      clrf         TRISB
;      movwf      TRISB            <- what's this for?
      banksel      PORTB
      movlw      b'11111111'
      movwf      PORTB
      banksel      CMCON
      movlw       b'00000101'
      movwf      CMCON
      banksel      PIE2
      bsf         PIE2,CMIE
      banksel      INTCON
      bsf         INTCON,PEIE
      bsf         INTCON,GIE
LOOP
      goto       LOOP          ; You don't want to fall to INR.
INR
      banksel      PORTB
      movlw      b'00000000'
      movwf      PORTB      ; <-- maybe you need this?
      goto          INR
      RETFIE
End
motion said:
   INR
      banksel      PORTB
      movlw      b'00000000'
      goto          INR
      RETFIE
This routine doesn't ever exit, the 'goto INR' will keep it in a permanent loop - presumably it's only partly written so far?.
Nigel Goodwin said:
motion said:
   INR
      banksel      PORTB
      movlw      b'00000000'
      goto          INR
      RETFIE
Thanks guys, I'll try it right away. Yes it's just a test, later it should set a relay and stuff, but I first wanted to get this straight so later on I could be sure nothing is wrong with this part of the code.
In the finished version, since you used the W and STATUS registers, don't forget to save their context at the beginning of INR and restore them prior to RETFIE.
PROCESSOR 16F88
__config 0x1F04
ORG 0x00
goto Main
ORG 0x04
goto INR
Main
banksel TRISA
movlw b'11100111'
movwf TRISA
clrf TRISB <- you wont need this
; movwf TRISB <- if you will not use the PORTB then you dont need to setup it's direction
banksel PORTB
movlw b'11111111' <- high output in PORTB is because of this
movwf PORTB <-----------------------'
banksel CMCON
movlw b'00000101'
movwf CMCON
banksel PIE2
bsf PIE2,CMIE
banksel INTCON
bsf INTCON,PEIE
bsf INTCON,GIE
LOOP
goto LOOP ; The program will stuck here 4ever, instead of runing the port value for your control logic
INR
banksel PORTB
movlw b'00000000'
movwf PORTB ; <-- maybe you need this? (motion is right !!)
goto INR
RETFIE
End
If you don't know how to program in assembler why don't you try C ??
You have many C compilers for the Pic Family for the 16XXX you need the MPLAB C16 and obviously the IDE too :)
Anyway the code is a little bit confuse since i don't know what you really whant to make.
Well greetings from Portugal !! :D
