What mean : tris PORTA
savnik
I have the below code:
trisabuf VAR BYTE
movlw 0x10 ; 00010000 - RA4 is entry
movwf trisabuf
bsf trisabuf,3
movf trisabuf,W
tris PORTA
What mean : tris PORTA ;
This mean that PORTA = trisabuf ;
On older versions of the PIC architecture there was a specific instruction that loaded the the TRIS register. On the newer versions you use a move instruction just like every other file register. If you read the datasheets really carefully they discourage the use of the dedicated instruction in favor of the more generic move instruction
Papabravo said:
On older versions of the PIC architecture there was a specific instruction that loaded the the TRIS register. On the newr versions you use a move instruction just like every other file register. If you read the datasheets really carefully they discourage the use of the dedicated instruction in favor of the more generic move instruction
Yes is for PIC16C54
savnik said:
Yes is for PIC16C54
On such an old device there is no alternative to the TRIS instruction because that register does not have a valid register file address.
savnik said:
I found:
bcf _trisabuf,3
bsf STATUS, RP0
movf _trisabuf,W
movwf TRISA
bcf STATUS, RP0
I use for pic16f628a
Is there some reason for using '_trisabuf'?, instead of just
	   bsf	 STATUS, RP0
	   bcf   TRISA, 3
	   bcf	 STATUS, RP0
