What can reset PORTx ?
PIC2PIC
I made a code for communicating PIC1 to PIC2 .Both PICs are 16f877.The code uses UART. Once it receives data it send it to PORTA (in the PIC1) and PORTB (in the PIC2). Program is working, but something makes PORTs to turn off and on all the time and it is not supposed to do that. I guess something reset PORTs .
What can reset PORT ? It is not WDT, POR, BOR. I don't know what to do anymore . Any suggetions.
Here is Interrupt service routine. The job of ISR is to take a data from RCREG when it gets there and put it on PORT (PORTA or PORTB depending which PIC). There is also code for transmitter I will post later
Let's examine ISR first. Is it something wrong with it.
;ISR
org 04h
;disable interrupts
banksel PIE1
bcf PIE1,TXIE
bcf PIE1,RCIE
bcf INTCON,PEIE
bcf INTCON,GIE
;disable reception and transmition
banksel TXSTA
bcf TXSTA,TXEN
banksel RCSTA
bcf RCSTA,CREN
;save working and status register
banksel W_Save
movwf W_Save
movf STATUS,W
clrf STATUS
movwf STATUS_Save
;accept data and put it on PORTA
banksel RCREG
movf RCREG,W
movwf PORTA
;clean buffer
movf RCREG,W
movf RCREG,W
;restore working and status register
banksel W_Save
movf STATUS_Save,W
movwf STATUS
movf W_Save,W
;enable reception and transmition
banksel TXSTA
bsf TXSTA,TXEN
banksel RCSTA
bsf RCSTA,CREN
;enable interrupts
banksel PIE1
bcf PIE1,TXIE
bsf PIE1,RCIE
bsf INTCON,PEIE
bsf INTCON,GIE
return
hi pic2pic,
Is the code the same as the code in your other thread Post number 5.??
If yes, I'll run thru it for you.:)
hi pic2pic.
The code from Post #5 runs OK in transmission and receive, BUT
the bcf RCSTA,CREN clears the RCREG receive buffer, so you never read the character in the RCREG!!!!
If you remove these two lines, the RCREG data is shown OK in PORTA.:)
;Disable reception and transmition
	banksel	TXSTA
	bcf	TXSTA,TXEN
	;banksel	RCSTA
	;bcf	RCSTA,CREN
EDIT:
Image shows received numer '9' in PORTA.
@ericgibbs
Thank you for answering. I changed code for both PIC as you say, but it is still the same, it is still blinking both PORTA and PORTB . Are you shore that clearing bit CREN will clear the RCREG buffer ? I did not find that in the data sheet for 16f877.
Also I forget to say that I receive data that I send from one PIC to other but it is just blinking the problem.
I ran your code on the Oshonsoft simulator and RCEN clears the contents of the RCREG.
I did not see any blinking on the PORTA.
I used the code from Post #5 of your other thread. Please post the full code and I will try on on the sim.
@ericgibbs
Unzip this file, view using Windows Media player.
I sent a '9' to the PIC via the UART, you can see the '9' in the RCREG.
I single stepped the program and at CREN, the RCREG is cleared.
  • pic2p.zip
Thank you all for your help.
I changed the code as you suggest me. Still is blinking. MCLR is high.
The new code is down (I try to comment it):
list p=16f877A ; list directive to define processor
#include <p16f877A.inc> ; processor specific variable definitions
errorlevel -302, -207
org 00h
goto start
;ISR
org 04h
movwf W_Save
swapf STATUS,W
movwf STATUS_Save
;banksel W_Save
;movwf W_Save
;movf STATUS,W
;clrf STATUS
;movwf STATUS_Save
;disable interrupts
banksel PIE1
bcf PIE1,TXIE
bcf PIE1,RCIE
bcf INTCON,PEIE
bcf INTCON,GIE
banksel TXSTA
bcf TXSTA,TXEN
;banksel RCSTA
;bcf RCSTA,CREN
;take data and put it on PORTB
banksel RCREG
movf RCREG,W
movwf PORTB
;clear buffer
movf RCREG,W
movf RCREG,W
;enable reception and transmision
banksel TXSTA
bsf TXSTA,TXEN
;banksel RCSTA
;bsf RCSTA,CREN
;enable interrupts
banksel PIE1
bcf PIE1,TXIE
bsf PIE1,RCIE
bsf INTCON,PEIE
bsf INTCON,GIE
banksel W_Save
swapf STATUS_Save,W ; Restore Status and W
movwf STATUS ;
swapf W_Save,F ;
swapf W_Save,W ;
;banksel W_Save
;movf STATUS_Save,W
;movwf STATUS
;movf W_Save,W
retfie
start
radix dec
cblock 20h
brojac,brojac1,podatak,aktiviraj_transmisiju,STATUS_Save,W_Save
endc
; setting TRIS/A/B/C
banksel TRISB
movlw 0ffh
movwf TRISA
movwf TRISC
movlw 00h
movwf TRISB
;Seting UART
movlw b'00000110' ; all analog pins = digital
movwf ADCON1
banksel PIE1
movlw b'00100000'
movwf PIE1
movlw b'11000000'
movwf INTCON
banksel SPBRG
movlw 0x0C
movwf SPBRG
movlw b'00100100'
movwf TXSTA
banksel RCSTA
movlw b'10010000'
movwf RCSTA
;Setting interrupts
banksel PIE1
bcf PIE1,TXIE
bsf PIE1,RCIE
movlw b'11000000'
movwf INTCON
Main
call Trans ;call routine for sending data
call Pauza ;make a pause
goto Main ;all the time
;Subroutine
Trans
banksel INTCON
bcf INTCON,GIE
banksel PORTA
movf PORTA,W
movwf TXREG
banksel TXSTA
WtHere btfss TXSTA,TRMT
goto WtHere
banksel INTCON
bsf INTCON,GIE
nop
return
Pauza
movlw 50
movwf brojac1
mala_pauza_1
movlw 100
movwf brojac
mala_pauza
decfsz brojac,f
goto mala_pauza
decfsz brojac1,f
goto mala_pauza_1
return
end
ho pic2pic,
Downloaded your code, get back to you later.:)
I have tidied your code and removed parts that were repeated or unnecessary. The biggest problem I could see was that you enabled TX interrupts and didn't service them. Edit, just noticed it was bcf PIE1,TXIE not bsf so you weren't enabling the TX interrupt.
Here is the tidied code,
		org	00h
		goto	start
		org	04h
		movwf	W_Save
		swapf	STATUS,W
		movwf	STATUS_Save
		banksel	RCREG
		movf	RCREG,W
		movwf	PORTB
		banksel	W_Save
		movwf	STATUS		;
		swapf	W_Save,F	;
		swapf	W_Save,W	;
		retfie
start
		radix	dec
		cblock	20h
		endc
		banksel	TRISB
		movlw	0ffh
		movwf	TRISA
		movwf	TRISC
		movlw	00h
		movwf	TRISB
;Seting UART
		movwf	ADCON1
		banksel	SPBRG
		movlw	0x0C
		movwf	SPBRG
		movlw	b'00100100'
		movwf	TXSTA
		banksel	RCSTA
		movlw	b'10010000'
		movwf	RCSTA
;Setting interrupts
		banksel	PIE1
		bsf	PIE1,RCIE
		movlw	b'11000000'
		movwf	INTCON
Main
Trans
		banksel	PORTA
		movf	PORTA,W
		movwf	TXREG
		banksel	TXSTA
		goto	WtHere
		return
Pauza
		movlw	50
		movwf	brojac1
mala_pauza_1
		movlw	100
		movwf	brojac
mala_pauza
		decfsz	brojac,f
		goto	mala_pauza
		decfsz	brojac1,f
		goto	mala_pauza_1
		return
		end
Notice how easy it is to read. That is because I typed
 before it and
after it.
ho pic2pic,
Your program works OK, both in send and receive using the Oshonsoft simulator.
No sign of blinking LED's [port pins] on the PIC, the pins show and hold the data steady.
As pointed out, your code needs a tidy.
The problem must lie elsewhere in your circuit.:)
You say the LED's flash, can you give us more details of what is actually being seen.
Here is video capture of situation. Is not high quality. One can see LED on and LED off.
  • vidcap0001.zip
I see on the video that both sets of LED's are flashing at exactly the same time.
I cannot see any large decoupling capacitors on the power rails.???
The program runs without any problems.
I feel sure you have a hardware problem, check the power supply lines to the project board.
Use a scope or DVM to check if the power 'dips' when all the LED's are on.
EDIT:
How are you setting the CONFIG bits.?
Add this line just above the 'org 0x0000'
__CONFIG _CP_OFF & _WDT_OFF & _BODEN_OFF & _PWRTE_ON & _WRT_OFF & _LVP_OFF & _CPD_OFF
Add the required CONFIG to suit your osc.
Hi @ericgibbs
Thank you. My supply voltage is stable 5 V. I don't put CONFIG bits in code because program for transmit HEX file from my computer to PIC overrides CONFIG bits set in code. I use WINPICPRO 1.91 and I set fuses always "POWER UP" and "BROWN OUT" as check other clear, and XT for oscillator. I never had any problems before.
Is it possible to someone build the same circuit, to check if I am wrong. Its really simple.
One need :
2 -16f877
14 - LED and 14 resistors for LED (For PORTA and PORTB)
2 - chrystal
4 - 27 pF capacitors
Supply stable 5 V.
Just put LED and resistors on PORT/A/B. Connect what must one for PICs, set the program, connect two PICs . And that's it.
One need :
2 -16f877
2 - chrystal
Supply stable 5 V.
I have one 16F877A circuit already built, I could reprogram the PIC and link it to my PC via the RS232. I will get back to you later today.
Hi @ericgibbs
How do you set the WDT?
