parag_gadge
Hello Everybody
Good Day!!
currently I am working on the leak detection system for one of my project and I want to make it simple instead of making it complicated. I need you advise in order to make this alarm system, Details for leak monitoring panel
1) I am looking for a water leak alarm monitoring panel
2) I want to use the SPDT relay solid state type for logic function
3) This leak monitor will receive signal from a ultrasonic leak sensor
4) The sensor signal will be normally open type
5) The sensor relay voltage is 24 volt DC
6) Hence the Alarm module will work on 24 volt DC power supply
7) This panel will be capable of handling 10 sensors at a time
8) In leak occurs then the signal status will change to NC
9) I want common alarm/buzzer on the alarm model
10) I want common muting switch on the alarm model
11) I want to reset the panel if I push the Muting switch
12) Each sensor will have separate LED indication light
13) Also I want to relay signal to BMS system
I hope I have included all the details and you can help me with guiding ladder logic. I hope ladder logic will be same for 2 or 10 sensors hence i need a kick start from your end.
Thanks in advance.
Parag G
Good Day!!
Thanks in advance.
Parag G
