voice recording using 8051 mic
piyush_it1
kindly give me information regarding any 8051 based digital voice recorder.
i found this application at ATMEL site but it was using advance ATMEGA8535.
If anybody has any information regarding it kindlly share.
The problem persists with serial peripheral interface controller in ATMEGA chip. Also as recording is done at very high speed i need to interface a FLASH instead of EEPROM. Can you suggest some solution?
What are the specs of that SPI controller? You use the direct cross components for that. Check on various websites of manufacutres for direct cross. I will go through it and will let you know if any.
Specify the speed. Instead can you not use your PC for that. With serial interface. You will get very high baud rates.
