view most significant bit
ibwev
How do I view the most significant byte of a 2 byte variable? I have attached a section of code that I am using. The variable "RPM" under View:Watch of MPLAB is only1 byte long.
  • helpac.txt
would that be under "view" then "watch" ? i'm curiouse also, i've been just movfw then movwf of say portc????
Thanks for the response.
When I declared the 2 byte variable, I set it up this way:
variable res 2
To be able to view the variable, should I set it up this way:
variableLOW res 1
variableHIGH res 1
View variables under View:Watch of MPLAB then "Add SFR" (Special Function Register) and/or "add GPR" (General Purpose Register). Apparently, only 1 byte of a variable can be viewed.
With MPLAB (using assembler) you can view and modify from a single bit to 4byte floating point numbers. Add the variable to Watch, right click it, popup allow you to select format.
