    Dismiss Notice
Vcc??
Discussion in 'General Electronics Chat' started by gtiboy2001, Oct 9, 2002.
  1. gtiboy2001
    gtiboy2001 New Member
    Oct 9, 2002
    3
    0
    Hey everyone, I'm new to the world of electronics and am trying to figure out how to read a schematic. I can see that there are alot of references to Vcc on a particular schematic I'm looking at? What does the Vcc mean? Does this refer to the positive side of a power supply and GND refer to the negative??
    Thanks for your help!!
  2. elegeek
    elegeek New Member
    Jul 18, 2002
    12
    0
    u r right
    hi
    u were right abt the vcc.its the supply voltage and can be called the saturation voltage ie the max value which can be obtained from the particular device neg supply need not neccesarily refer to gnd.its just
    a point for lower potential.this might right now sound a bit confusing
    ull under stand with experience.check out dual power supply ,i think u ll get an idea of i am trying to convey.
    bye
  3. kinjalgp
    kinjalgp Active Member
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    In transistor based circuits the power supply connected to the collector of a transistor to bias it is called Vcc (Collector voltage). Similarly in FET(Field Effect Transistor) based circuits you will find Vdd instaed of Vcc. In FET instead of collecter there is a pin called Drain and the supply voltage applied at Drain in called (Vdd).
    Also in transistors the reference point is taken as ground (0v but not necessarily be). In FETs it is termed as Vss (Source voltage)
    Hope you got the answer.
    Kinjal
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. kinjalgp
    Oct 28, 2002
    1,851
    3
    INDIA/USA
    Now you'll also have a question that even IC based circuits have Vcc and Vdd. Thats because ICs actually contain Transistors and FETs in them. Thats the reason!
  6. star882
    star882 New Member
    Sep 26, 2002
    36
    0
    Vcc is the positive supply, gnd is ground, and Vdd is negative supply.
  7. pebe
    pebe Member
    Sep 24, 2002
    354
    1
    Ellon - Scotland
    You are wrong - kinjalgp is right.
Share This Page
