Using MCU LCD data line I/O as analog inputs
Mosaic
Is it acceptable to dual use the lcd data out lines as analog inputs as well during program execution when the LCD is not being fed data?
I want to use 47K NTC thermistors as temp sensors on PORTB0,1,2,3 which are also the LCD data lines.
You need to read the LCD data sheet very carefully.
>Pull up resistors? 10k +/-30%?
>Input leakage? +/-20uA
How will this effect the 47K NTC and what ever circuit you add to drive the NTC.
If the NTC (+ resistor or whatever) are on the data lines, can the (micro and LCD) pull the data lines high and low.
Well I am short just 2 adc channels. I guess I can reuse the analog inputs sharing a couple of the data lines once the thermistor doesn't load the line by more than 10K. I was intending to measure the temp by loading each line with a 10K pull up and the 47K thermistor pull down.
Judging from the datasheet:
The highest temp of the thermistor should not exceed 65 deg C. Which is ok for my app.
I am using it in 4 bit mode.....still short 2 adc. Those data lines ought to be high impedance compared to the sub 50K impedance of the thermistor.
So no data sheet on the LCD you are using....
I looked up two 3.3V and two 5V LCD displays and all have +/-1uA of input leakage on the data lines. Most likely the input current is much better than that.
Do you need help to know how much +/-1uA will effect your reading?
