I was apparently born with 7 senses instead of 5. I have the "6 th sense". The seventh is sensitive to the second derivative of barometric pressure vs. time or I know when it will rain.
Log10(x) is easy. It's just the exponent.
Any number raised to the 0 power is 1. It's just a definition.
LOG base 10 of 25 is 1.397940009
LOG base 10 of 50 is 1.698970004 which is a number between 1 and 2.
LOG base 10 of 90 is 1.954242509
LOG base 10 of 99 is 1.995635195 (nearly 2)
The LOG function is not defined for 0 or negative numbers.
The graph is read almost the same way as a linear graph. In the graph above there are 10 divisions between 1.00M and 10.00M. Finding the value between tick marks is called interpolation and that's much harder.
RC is just R * C or the product of R & C.
i.e. R = 10 M ohms, C = 1 uf
RC = 10,000,000 * 1E-6
The ripple gets reduced when the capacitance is greater. You saw that with the power supply filter where you changed the value of the capacitance and saw the resulting ripple decrease when you increased the capacitance.
I don't really want to diverge into a discussion about db yet, but some caveats are that db has to have a reference level. In electronics, there are both voltage and power references.
dbV is db referenced to 1 volt.
dbmV is referenced to 1 mV
db in CBB's example is referenced to gain or amplification. 0 db is no amplification. .
Xc I pulled out of a hat. For that we have to take a math detour and learn about vectors and right triangles.
We covered the E numbers, but I guess you slept through the lecture.
ripple = usually an unwanted AC component. You want 5 V DC, but not 5 V DC that varies from 4.8 to 5.2 V over time. The variation is ripple. It's usually expresed as an RMS voltage in % of the desired output like 0.1% RMS or say 10 mV p-p.
For now, Xc is the magnitude of the capacitive reactance at one particular frequency and it has units of ohms. It ACTS SOMEWHAT LIKE a resistor at the single frequency it is computed at.
