    Dismiss Notice
UART-Keypad-lcd interfacing with 8051
Discussion in '8051/8951' started by bobparihar, Feb 27, 2015.
  1. bobparihar
    bobparihar New Member
    Sep 25, 2014
    10
    0
    i am doing a project in which there is a serial communication between two 8051 microcontroller.
    at transmitting side there is a 4x4 keypad attached at one of the port of 8051
    at receiving side there is a 16x2 LCD attached
    i am simulating it on Proteus first... but there is an error as soon as i start the simulation of the program..
    i am unable to understand this error.. ( see the attached screenshot of protues)
    help me to get rid of this error
    this is code of transmitting side.............................
    Code (c):
    #include<reg51.h>
    void serial(void);
    void serial(void)
      TMOD=0x20;        //timer 1, mode 2(8-bit autoreload) to set baud rate
    TH1=0xFD;        //-3 to TH1 for 9600 baud rate
    SCON=0x50;        // 8 bit txion, 1 start 1 stop bit, REN enable for both txfr and rxve
    TR1=1;         // start timer
    void trans(unsigned char);
    void trans(unsigned char a)
      SBUF=a;
      while(TI==0);
      TI=0;
    void main()
    unsigned int ar[]={0xE7,0xD7,0xB7,0x77,0xEB,0xDB,0xBB,0x7B,0xED,0xDD,0xBD,0x7D,0xEE,0xDE,0xBE,0x7E};
    unsigned int a,b,c,i;
        serial();
    while(1)
           P1=0x0F;
           while(P1==0x0F);
           a=P1;
           P1=0xF0;
           b=P1;
           c=a|b;
           for(i=0;i<16;i++)
               if (ar[i]==c)
               trans(i);
    now this is code of receiving side.................................................
    Code (c):
    #include"lcd1.h"
    void main()
    int a;
    init();
    while(1)
      while(RI==0);      // check if all the bytes get received
      a=SBUF;        // place sbuf in a
      num(a);
      RI=0;          // clear RI so that another byte will recive
    [B]header file code for lcd..[/B]
    #include<reg52.h>
    sbit rs=P3^2;
    sbit rw=P3^3;
    sbit en=P3^4;
    void dat(unsigned char);
    void cmd(unsigned char);
    void delay(unsigned int);
    void print(unsigned char *);
    void init();
    void num(unsigned int);
    void init()
       cmd(0x38);
       delay(100);
       cmd(0x0E);
       delay(100);
       cmd(0x06);
       delay(100);
       cmd(0x01);
       delay(100);
       cmd(0x80);
       delay(100);
    void cmd(unsigned char x)
      P2=x;
       rs=0;
       rw=0;
       en=1;
       delay(1);
       en=0;
    void dat(unsigned char y)
       P2=y;
       rs=1;
       rw=0;
       en=1;
       delay(1);
       en=0;
    void delay(unsigned int z)
      int j,i;
       for(i=0;i<z;i++)
         for(j=0;j<1275;j++);
    void print(unsigned char *p)
       while(*p!='\0')
         dat(*p);
         p++;
    void num(unsigned int a)
       int b,c=1;
       b=a;
       while(b>9)
         b=b/10;
         c=c*10;
       while(c!=0)
       {   delay(50);
         dat((a/c)+48);
         a=a%c;
         c=c/10;
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,150
    907
    Rochdale UK
    ONLINE
    Both micro's are U1.... One needs to be renamed to U2....
  3. bobparihar
    Sep 25, 2014
    10
    0
    thanks that helped
Share This Page
