ACK
Many, if not all Application Notes and PowerPoint presentations by Microchip tell the user to check for an ACK from the slave. In fact, there is some emphasis on polling the ACKSTAT bit. However, the sample code from Microchip does not always do that. Here's one example:
Checking for an ACK is commented out as being optional, but no advice is rendered to help the reader decide whether checking for an ACK is advised. In line with that, could one substitute just checking ACKSTAT instead of checking SSPIF (assuming an interrupt is not enabled for SSPIF)?
Recover after a Reset
There is a need to have the slave(s) in a known state after a reset or other mess-up. On the Microchip forums, there is this suggestion:
"Send a START condition, then clock out nine 1's, send another START, then send a STOP." An alternative from the DS3231 datasheet is: "Toggle SCL until SDA is observed to go high, then generate a START condition."
Since I will be using the DS3231, my inclination is to use the latter protocol. Is that an alternative, generally applicable protocol, or is there even such a thing as a generally applicable protocol?
Thanks, John
TX
bcf STATUS,RP1
bcf STATUS,RP0 ; Select Bank 00
bcf PIR1,SSPIF ; Clear SSP interrupt flag
movf datao,W ; Copy datao to WREG
movwf SSPBUF ; Write byte out to device
tx_wait
btfss PIR1,SSPIF ; Check if operation completed
goto tx_wait ; If not, keep checking
; bsf STATUS,RP0 ; Select Bank 01
; btfsc SSPCON2,ACKSTAT ; Check if ACK bit was received
; goto ackfailed ; This executes if no ACK received
retlw 0
Thanks, John
