    Dismiss Notice
Turns ratio
Discussion in 'Homework Help' started by FramedShirt, Oct 3, 2015.
  1. FramedShirt
    FramedShirt New Member
    Oct 3, 2015
    2
    0
    Guys, I have an assignment here which I have been trying to calculate for almost an hour but I still didnt get the answer. Heres the problem.
    If Ep=120 VAC and Es=25.2 VAC, determine the turns ratio (NS:NP) of the transformer.
    Quick and appropriate response will be highly appreciated. Thank you.
  2. Inquisitive
    Inquisitive Super Moderator
    Aug 31, 2011
    924
    86
    Georgia, USA
    [​IMG]
    Where P = Primary, S = Secondary
  3. Ratchit
    Ratchit Well-Known Member
    Mar 12, 2008
    1,934
    78
    Why are you having a problem with this? Es/Ep = Ns/Np gives an answer of 25.2/120 = 0.21
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. FramedShirt
    Oct 3, 2015
    2
    0
    What I need obviously is the ratio .. and yeah BY the Way I already got the answer.. and its 21:100.
  6. Inquisitive
    Aug 31, 2011
    924
    86
    Georgia, USA
    Np = Number of turns in the primary
    Ns = Number of turns in the secondary
    Ep = Voltage of primary
    Es = Voltage of secondary
    Ip = Current in primary
    Is = Current in secondary
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    So, the ratio is:
    [​IMG]
    There are 4.76 turns in the primary to 1 in the secondary.
    • Informative Informative x 1
  7. KeepItSimpleStupid
    KeepItSimpleStupid Well-Known Member Most Helpful Member
    Oct 30, 2010
    9,908
    1,094
    Turns ratio is usually expressed as a ratio of two integers, so 476:100, so factor the numerator and denominator and reduce it.
    e.g if it were 15:5 = (3*5)/5 = 3:1
  8. mvs sarma
    mvs sarma Well-Known Member
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    in general
    they wont wind a transformer at 1turn per volt. Instead they use 4Turns per volt for a good trafo.
    worst case cheap ones use 2.5turns /V. Such ones core gets dam hot even at 10% loading.
  9. KeepItSimpleStupid
    Oct 30, 2010
    9,908
    1,094
    Anyway 476 = 2*2*119
    and 100 = 2* 2* 5 * 5
    So 120/25.2 = 4.6:1 = 476:100 = 119:25; They are all right, but typically it's expressed in a ratio of integers.
  10. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,437
    933
    Canada, of course!
    I have a Chinese transformer that came with a cheap product. Its output is rated at 9VDC/100mA but is about 19V with no load. It gets very hot even with no load. With a 100mA load its output is its rated 9VDC.
  11. tunedwolf
    tunedwolf Well-Known Member
    Aug 9, 2006
    1,080
    62
    UK
    Must be one of those magical Chinese ones, I don't think I have ever seen DC make it out of a transformer, alive at least :p
  12. audioguru
    Mar 16, 2004
    32,437
    933
    Canada, of course!
    My cheap Chinese "transformer" (wall wart adapter) transforms the 120VAC into 9VDC.
  13. tunedwolf
    Aug 9, 2006
    1,080
    62
    UK
    I knew what you meant bud, I was just joking with you :D
Share This Page
