Touchscreen driver issue
bibinpaul
I am using GLCD 128x64 Touch Screen from Mikroelectronica on a project. The touchscreen driver circuit is copy of the one on PIC18 development board(Easy PIC V7). I am using PIC18f67k22 to control the display and touchscreen.
The problem I am facing is, I get a full 0 Volts to 5V on one axis of the touchscreen. On the other axix, the variation is very small 0.7V to 1.7V. I have tested this with the sample code given by Mickro electronica. I have worked on touchscreen and familiar with driving the touchscreen and reading the ADC values.
Issue appears to be on the driver circuit comprising of transistors and resistors. I have seen similar designs with different resistor values.
Any help is really appreciated.
Thanks,
Paul
Same!!! I ditched the driver board and used the TFT touch driver instead..
The circuit is simple... Each drive has a 300k pullup with a 47nf decoupling cap..
I use a pic32 so
Drive X and read Y are on one ADC pin
Drive Y and read X are on another...
The circuit is in the help file under Touch Panel TFT... This is a FAR better solution...
Thanks for the reply, Ian. Ur design is simply great.
I was also planning to see if it works from GPIO/ADC pins.
unfortunately, I cannot change the design(or add a touchscreen controller). Hardware is already designed by someone else, copying the Mikroe design.
Looks like its some odd resistor combination.
cheers,
paul
