Tek 465B Help
mmessuri
Ok I must admit that I am an oscilloscope newbie (spent most of my time with Logic Analyzers) and I have just picked up a used Tektronix 465B. After reading the manual that came with it and following the instructions for pre-setting the scope I have came across a newbie question that I cant seem to find an answer to just yet and thusly is the reason of this post: How do I set the voltage trigger level (i.e. how do I get the scope to triger at 5 volts verses 3 volts - on the positive side of the slope)
Thanks for any help that you may provide (I sure could also use some links on tutorials on how to use this particular scope),
-- Michael --
How do I set the voltage trigger level (i.e. how do I get the scope to triger at 5 volts verses 3 volts - ..... )
You can't set it to a particular, known, threshold.
You can switch the triggering so that it operates on the positive or negative going slope of the waveform.
Don't know about this particular one, but a Google search for "oscilloscope tutorials" should give you some useful links.
David:
Thanks for the information, that is exactly what I needed to know (the scope that I used in the office allowed me to set a particular level for the trigger).
Have a great day.
-- Michael --
