ibrar0 said:Hi, if there is any good site or pdf for electronics part's names which have same or similar functionality
So, that we can use in our project as a substitue. if we do not finds some one....
ibrar0 said:ok then can any one guid and tell replacement of TL072 amps used in audio amplifier????
I would use http://www.datasheets.org.uk/ to find the specs on the part.Hi, if there is any good site or pdf for electronics part's names which have same or similar functionality
That would only work if the soil has a high mineral content:audioguru said:Or do gardening instead!
The poor guy who lives in the middle of a desert and his local "market" doesn't stock common electronic parts would find growing a plant a challenge. To keep the plant and himself watered enough to stay alive.kchriste said:That would only work if the soil has a high mineral content:
ibrar0 said:doesn't stock common electronic parts
something may be common in your city,it is not necessary that will must available in my country,
You may be assuming that your question has a good answer. Not all questions do have good answers. The fact of the matter is that there is no comprehensive electronic parts cross reference that is freely available to the members of the general public. Electronics distributors have such a facility, but you need to be a customer. You may not like the answers you get here, but why should we sugar coat reality to cater to your sensitive feelings?ibrar0 said:doesn't stock common electronic parts
if you don't have patience, for newcomers questions you may also join gardening where no one(e.g plants) can ask you question which makes you hot.......?
its my advise to you audio_guru be patience....and calm.....
similar functionality means simple op-amp if we want to simple amplify signal we can use 741,lm358 etc.
if you don't hav good answer to any post of this forum.you are not forced to answer....you may listen music...or audio...
A microphone is a transducer to convert sound to an electrical signal.chir said:hey does any body thought o transduser to convert sound into light
