    Dismiss Notice
Standard Via Diameter
Discussion in 'Circuit Simulation & PCB Design' started by Jon Wilder, Apr 22, 2017.
  1. Jon Wilder
    Jon Wilder Active Member
    Oct 22, 2010
    859
    82
    Fresno, CA
    On a 4 layer board with power, ground, and signal planes, what's the standard drill diameter used for through and blind vias?
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,148
    907
    Rochdale UK
    ONLINE
    In proteus they specify this
    But I also think it depends on the track size...
  3. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    Go the web-sight of your PCB factory and see what they can do. (depends on cost)
    A CAD program can do anything but the real question is in the ability of the PCB machines.
    You are looking for min drill size, min trace, min rings.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Jon Wilder
    Oct 22, 2010
    859
    82
    Fresno, CA
    Their minimums are 4mil trace, 8mil drill, and 5mil annular ring. But I'm wanting to know what a "standard" via size is. Doesn't necessarily mean I want to take things to the minimum.
    Most of my traces are 20mil with 10mil being the smallest on a few traces.
  6. DerStrom8
    DerStrom8 Super Moderator Most Helpful Member
    Aug 9, 2010
    5,484
    503
    Vermont (GMT-5:00)
    It really comes down to the thickness of your board. You generally want no greater than a 5:1 barrel length:diameter aspect ratio. This means that if you have a 1.6mm (0.062") PCB and your via goes from the top layer to the bottom layer, the diameter should not be less than 1.6/5 = 0.32mm (0.0124") in diameter. Many manufacturing companies can offer better (higher) ratios, but to be on the safe side the 5:1 is usually a safe bet. The smaller the ratio, the more reliable the via will be. Too high and you won't get uniform plating of the hole, and you risk cracking of the inside of the barrel.
  7. RadioRon
    RadioRon Well-Known Member
    Oct 7, 2005
    1,755
    53
    BC, Canada
    There is no standard, really, but there is popular. For example, 16 mils is popular and presents no challenges to the fabricator. You also need to be sure to provide a large enough annular ring around that hole for the fabricator to avoid problems. I think that an 8 mil annular ring would be ok, so the total diameter of the via pad would be 16 + 8 +8 =32 mils. When you do a plated through hole, you should be specific about what your diameter means. You could specify that the diameter is measured after plating, which means that the fabricator would probably choose an 18 mil drill bit, drill the hole and then plate another 1 mil of copper on the wall of the hole for a net diameter of 16 mils. Or you could specify that the fabricator actually drill with a 16 mil bit and allow them to plate the hole down to around 14 mils or so. If you don't give them any details about what your diameter means, they usually assume you want this diameter after plating.
    Blind vias are a bit more complex and you should always consult with your fabricator on appropriate sizes.
  8. ronsimpson
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    Most board houses publish a list of drills they keep in the machines.
  9. Cicero
    Cicero Active Member
    Nov 21, 2014
    335
    36
    UK
    For 4layer board projects down to 7mil spacing, I usually make the through vias with 0.6mm holes, and 1.2mm pads. Not sure if there's any industry agreed standard/average.
    No 4 layer board I've done has even needed a blind via, only on the much larger layers boards.
  10. Jon Wilder
    Oct 22, 2010
    859
    82
    Fresno, CA
    Thanks all. I've got my board set for all thru vias at 12.4mil/5:1 aspect ratio. Board passes DRC as well as the board house's DFM check.
Share This Page
