Spice model for transformer?
carbonzit
Active Member
Has anyone got a Spice model for a transformer?
I understand a transformer can be constructed from two inductors using mutual inductance statements/parameters, but unfortunately I don't know how to do this.
I also understand that there are many possible parameters for a transformer. For my purposes, a "generic" model (one which assumes no parasitic capacitance and near-zero resistance, for example) would do fine at this point. A simple "plug-n-play" model, if one exists, would be perfect.
Any help much appreciated.
hi cz.
Two asc files, one is a dual secondary, note the 'K1' string.
EDIT:
You should this one helpful, shows different voltage options. For a a 230Vac 50Hz input
BasicTxr1
  • Tapped1.asc
  • txr2.asc
  • BasicTxr1.asc
Wow, that was fast. Thanks!
So all I need are two inductors and the "K L1 L2 1" Spice directive?
I understand that the inductance ratio is the square of the turns ratio, correct? (Source: LTwiki)
I'm going to give it a spin now ...
cz,
Dont forget to use a States mains voltage, the voltage in the 'source generator model' has to be 110V * 1.414
Actually, I'm modeling a flyback transformer, not a power transformer.
I'm attempting to model one of Colin's circuits, a 3-volt to 5-volt step-up flyback converter (it's the power supply for this project).
Getting weird results. First time out I got nothing, so I flipped one of the inductors. Now it grinds and grinds, doesn't seem to want to converge on a solution. I copied this directly from his schematic, and I trust that his circuit is tested and works. So I guess I must have made a boo-boo somewhere.
I used a 1KΩ load on the output side: maybe not enough? will try a smaller R.
My simulation is attached. (Note: inductances are wrong. Fixed them but still doesn't work right.)
At least I now know how to make a transformer in LTspice.
  • 3v-9v converter.asc
WHERE is your circuit Ground Symbol.:rolleyes:
EDIT:
Can you post the original circuit diagram.?
Whoops. OK, put it in, but still no joy. Hmm, I wonder if Colin is around ... must be something verrrrry mysterious about his little circuit. I'm getting less than 2 volts out of it (supposed to be 5).
Oh well, if anyone has any ideas I'm listening, but otherwise I'm going to pack it in and try again later.
Hmm; choosing higher inductance values (200/600µH instead of 20/60) made a big difference. Getting expected results (including the ~20KHz spikes he described). New .asc posted below.
Spice are good!
Try using mH not uH values and try again, lets see.
