    Dismiss Notice
solar charge controller for 6v solar panle & 4.8v battery
Discussion in 'General Electronics Chat' started by moehao, Jan 11, 2017.
  1. moehao
    moehao New Member
    Jan 10, 2017
    19
    0
    Hi guys,
    I using a 6v solar panel to charge a 4.8v battery.
    I want to use the solar charge controller to reduce the solar panel voltage and monitoring the battery voltage.
    And if possible i also want to use the solar charge controller to stop charging the battery when the battery is fully charged or is discharged to other system.
    Is there any suggestion which type of solar charge controller i should use or is there any alternative solution by not using solar charge controller?
  2. spec
    spec Well-Known Member Most Helpful Member
    Oct 27, 2015
    5,828
    707
    Somerset UK GMT
    Hello moehao,
    can you answer these questions:
    (1) What type is the 4.8V battery: lead acid (LA), nickel cadmium (NiCd), nickel metal hydride (NMH), Lithium Ion (LiIon)? The terminal voltage of 4.8V would imply a stack of four NiCd or NMH cells.
    (2) What is the capacity of the battery (mA/Hours or A/Hours)?
    (3) What is the maximum power output of the solar panel (Amps)?
    To answer your question, in general you can either use a purpose designed off-the-shelf controller to do your job or possibly a switch mode power supply which, depending on your answers above, should be quite cheap and, in Singapore, should be freely available.
    spec
  3. moehao
    moehao New Member
    Jan 10, 2017
    19
    0
    Hi spec,
    The battery is NiMH cell.
    The capacity of the battery is 2550mAh.
    The power output of the solar panel is show 300mA, and I measure by the multimeter is about 220mA.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. spec
    Oct 27, 2015
    5,828
    707
    Somerset UK GMT
    Thanks Moehao- we like quick concise replies on ETO- they help us to find a solution for your solar cell application.
    spec
  6. moehao
    moehao New Member
    Jan 10, 2017
    19
    0
    Hi spec,
    I found this solar charge controller: Wincong SX01-3A 3A 6V 12V solar panel light controller Battery Charge Regulators
    i would like to ask is this solar charge controller good enough for my situation?
    Thank you
  7. spec
    Oct 27, 2015
    5,828
    707
    Somerset UK GMT
    Hi again Moehao,
    NMH batteries are the most difficult batteries to charge and especially so at a current of capacity/10 or less. In your case, the solar cell produces around 220 mA and the battery capacity is 2550 mAh. An explanation is here: http://batteryuniversity.com/learn/article/charging_nickel_metal_hydride
    I hate to do this because you have not asked for it, but would you consider changing to a lithium ion battery. A single 18650 LiIon battery would give you 3.6V at up to 3400mAh or two in series would give 7.2V at 3400mAh.
    Changing to LiIon batteries would give a much better and potentially cheaper system.
    Could you describe what the NMH battery is used for.
    Also could you describe how you are charging the NMH battery now?
    spec
  8. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    10,728
    499
    AZ 86334
    Unless portability is a big issue, even easier than LiIon to manage is a Sealed Lead Acid, like this one.
  9. moehao
    moehao New Member
    Jan 10, 2017
    19
    0
    Hi spec,
    The NiMH battery is used for store energy get from the solar panel. Then the energy inside the battery will use to run other item such as DCmotor.
    The battery is new bought and havent been charge before。
    Thank you
  10. moehao
    moehao New Member
    Jan 10, 2017
    19
    0
    Hi Mike,
    Actually I am planning to use a lighter weight battery. because my DC motor to run the system doesnt have high torque
    Thank you
Share This Page
