Soft ferrite's permeability in high frequency
pepekong
Hello,
I'm new here, I was looking for some help in my project. I'm interested in modeling the permeability for soft ferrites until 30Mhz (MnZn). I'm using a toroid with 15 spires, current 1A AC (it'll be constant) and variable frequency (40Hz-30MHz). So, could you help to understand which are the parameters or characteristics that I have to consider in soft ferrites to model them?
I'll be so greatful too if you give me some literature to read.
Hi there,
If you cant find anything else you can take a look on the Magnetics Inc. site. They have (or at least had) a lot of literature on magnetic materials that you
can read over and see if you can find what you need.
Why not use an air/plastic cored coil?
I would've thought the magnetic losses will be greater than the higher ESR an air coil will have.
