Sleep, Call Stack & Software Reset
Dan East
I'm using Sleep to "turn off" the PIC. When an interrupt turns it back on it continues program execution following the sleep call. However I want to reset the PIC when it wakes up. So currently I'm just jumping to my initialization routine and all is well. I do have one concern, and that is the call stack. The sleep may be called from within subroutine(s), thus the call stack is dirty after my "reset".
So finally here are my questions.
Is it okay to just let the stack overflow since I don't need the elements that are pushed off of the bottom?
Is there a way to clear the stack without using return / retlw?
Can a PIC be reset via software?
Thanks!
Dan East
Which PIC family are you working with?
To answer your questions under the PIC16 family:
The stack pointer will overflow and wrap around to the start. This does not pose any problem if you use stack only up to 8 calls deep.
None and IMO not needed.
No way that I know of except enabling the watchdog timer. But You can't have that enabled while using sleep.
To answer your questions under the PIC18 family:
A stack underflow or overflow can trigger a reset.
The STKPTR register is accessable and can be cleared by software.
The RESET instruction is available.
Thanks for the info! I'm using PIC12 and PIC16 family PICs. So I'll just let the stack overflow.
Dan East
