simplest 8051 interfacing with DS1307
All i need to know is from where i can get a simplest program in C for interfacing 8051 or any other micro with DS1307.
Regards,
Simran
Hi Simran,
Do you have the basic I²C routines? I can post C routines to access the DS1307 but you would need the basic I2C library.
Well...
i am not having basic i2c routines....
please help me in my other doubt...
what is wrong in my this program... see...
#include<reg51.h>
void main(void)
  sbit ravi = P1^0;
  while(1)
  ravi = 1;
  ravi = 0;
the error i am getting is :
I'm sorry but I'm not familiar with 8051. My guess is that the above should be,
#include<reg51.h>
#define ravi P1.0     //ravi = port1 bit 0
void main(void)
  while(1)
  ravi = 1;
  ravi = 0;
____________________________________________________________
#include<reg51.h>
sbit ravi = P1^0; /// define the port out side main....
void main(void)
while(1)
ravi = 1;
ravi = 0;
the cycle will be so fast that you will not see any change externally .........
better give it a try with a delay in between them
_________________________________________________________________
#include<reg51.h>
void main(void)
sbit ravi = P1^0;
while(1)
ravi = 1;
delay ();
ravi = 0;
delay();
__________________________________________________________________
So Mrs Simran
You might have got the correct reply for the above
you should add delay
NaveenCali
Hello,
Can any one look at my code and guess what i am doing wrong with my code.
I cannot read neither write to ds1307.
connected through port d bits 5 and 6
crystall oscillator 10Mhz but using hspll
have pull up resistors on both lines sda and scl
// Header: 8722 Project //
// PIC used: PIC18F8722 //
// Start Date: 1st Dec 2009
// Function for I2C //
//** HEADER FILES ********************************************************************/
#include <p18F8722.h>
#include <string.h>
#include <stdlib.h>
#include <stdio.h>
#include <usart.h>
#include <timers.h>
#include <delays.h>
#include <i2c.h>
//** CONFIGURATION BITS **************************************************************/
#pragma config OSC = HSPLL
#pragma config WDT = OFF
#pragma config LVP = OFF
#pragma config DEBUG = ON
//** FUNCTION PROTOTYPES *************************************************************/
void Init_Ports(void);
void Configure_I2C2(void);
void I2C2_Write(unsigned char Add, unsigned char Data);
void Write(unsigned char Input_Data);
unsigned char I2C2_Read(unsigned char add);
void SCL_high(void);
void SCL_low(void);
//** DEFINITIONS *********************************************************************/
#define IniDs1307 0x00
#define AddRDs1307 0xD1
#define AddWDs1307 0xD0
#define CLEAR 0
#define SET 1
#define BRGValue 0x63
//** GLOBALS *************************************************************************/
unsigned char Second, Minutes, Hours, Day, Date, Month, Year;
//** MAIN CODE ***********************************************************************/
void main(void)
Init_Ports();
Configure_I2C2 ();
I2C2_Write(0x07,0x00); // control register add 07, 00 as i am not using swqe, rs0, rs1
I2C2_Write(0x00,0x05);// control register for seconds,also CH=0 initialized for first time (bit 7), add = 0x00, value assigned 0x05
I2C2_Write(0x01,0x07);// control register for minutes, add = 0x01, value assigned 0x07 (just to see whther the RTC works)
I2C2_Write(0x02,0x06);// control register for Hours, add = 0x02, value assigned 0x06
I2C2_Write(0x03,0x02);// control register for Day, add = 0x03, value assigned 0x02
I2C2_Write(0x04,0x03);// control register for Day, add = 0x04, value assigned 0x03
I2C2_Write(0x05,0x02);// control register for Month, add = 0x05, value assigned 0x02
I2C2_Write(0x06,0x04);// control register for Year, add = 0x06, value assigned 0x04
Second = I2C2_Read(0x00);
Minutes = I2C2_Read(0x01);
Hours = I2C2_Read(0x02);
Day = I2C2_Read(0x03);
Date = I2C2_Read(0x04);
Month = I2C2_Read(0x05);
Year = I2C2_Read(0x06);
StopI2C2();
while(SET)
Nop();
PORTD = CLEAR;
LATD = 0b01100000;
TRISD = 0b01100000; // intialized RD6(SCL2) AND RD5(SDA2).
void Configure_I2C2 (void)
SSP2CON1 = 0b00001000;
SSP2STAT = 0b10000000;
SSP2ADD = 0x63;
//SSP2ADD = (BYTE) _I2C_BAUD_COUNT;
SSP2CON2bits.ACKSTAT = 1;
SSP2CON1bits.SSPEN = 1;
OpenI2C2(MASTER, SLEW_OFF);
//***********************************writes data to add***************************************************
PIR3bits.SSP2IF= CLEAR;
StartI2C2();
Write(0xD0);
IdleI2C2();
Write(Add);
IdleI2C2();
Write(Data);
IdleI2C2();
StopI2C2();
//***********************function of write***********************************
unsigned char data, i, Outbit;
data = Input_Data;
for (i = 0; i <= 7; i++)
Outbit=data&0x80;
PORTDbits.RD5 = Outbit;
data = data << 1;
SCL_high();
SCL_low();
while (SSP2CON2bits.ACKSTAT == 1) { }
//**************reads add and returs data**********************************
unsigned char dataa;
StartI2C2();
Write(0xd1); // to write
IdleI2C2();
Write(add); // address to read
IdleI2C2();
if (DataRdyI2C2())
getcI2C2();
dataa = SSP2BUF;
PIR1bits.SSPIF = 0; // clear flag
NotAckI2C2();
StopI2C2();
//dataa = (dataa & 0x0f) + (dataa>>4)*10; // chuyenthanh so thap phan
return (dataa);
void SCL_high(void)
PORTDbits.RD6 = 1;
Delay1KTCYx(1000);
void SCL_low(void)
PORTDbits.RD6= 0;
Delay1KTCYx(1000);
