    Dismiss Notice
Simple code in XC8 C builds but doesnt work for PIC18F26K20
Discussion in 'Microcontrollers' started by Flyback, Jun 8, 2017.
  1. Flyback
    Flyback Well-Known Member
    Jan 5, 2007
    1,989
    34
    Hello,
    The following XC8 C code for PIC18F26K20 Builds successfully but doesn’t work. Please help make it work?
    All it is supposed to do is output on RC2 what it reads as an input on RB0. (They are both Digital I/O ports)
    I cannot see why it wont work.
    The following is the crux of the entire code………..
    while(1) {
    if (PORTBbits.RB0 == 0) {PORTCbits.RC2 = 0;}
    __delay_ms(1);
    if (PORTBbits.RB0 == 1) {PORTCbits.RC2 = 1;}
    __delay_ms(1);
    …..surely there is nothing wrong with this?
    Here is the complete code listing……
    * File: main.c
    //This file is very simple code.
    //It simply puts out on RC2 what it reads on RB0. (HIGH or LOW)
    Generated Main Source File
    File Name:
    main.c
    Description:
    * Generation Information :
    Device : PIC18F26K20
    The generated drivers are tested against the following:
    Compiler : XC8 v1.38
    MPLAB : MPLAB X IDE v3.61
    #include <xc.h>
    #include <stdint.h>
    #include <stdlib.h>
    #define _XTAL_FREQ 16000000
    // CONFIG1H
    #pragma config FOSC = INTIO67 // Oscillator Selection bits (Internal oscillator block, port function on RA6 and RA7)
    #pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit (Fail-Safe Clock Monitor disabled)
    #pragma config IESO = OFF // Internal/External Oscillator Switchover bit (Oscillator Switchover mode disabled)
    // CONFIG2L
    #pragma config PWRT = OFF // Power-up Timer Enable bit (PWRT disabled)
    #pragma config BOREN = OFF // Brown-out Reset Enable bits (Brown-out Reset disabled in hardware and software)
    #pragma config BORV = 18 // Brown Out Reset Voltage bits (VBOR set to 1.8 V nominal)
    // CONFIG2H
    #pragma config WDTEN = OFF // Watchdog Timer Enable bit (WDT is controlled by SWDTEN bit of the WDTCON register)
    #pragma config WDTPS = 32768 // Watchdog Timer Postscale Select bits (1:32768)
    // CONFIG3H
    #pragma config CCP2MX = PORTC // CCP2 MUX bit (CCP2 input/output is multiplexed with RC1)
    #pragma config PBADEN = OFF // PORTB A/D Enable bit (PORTB<4:0> pins are configured as digital I/O on Reset)
    #pragma config LPT1OSC = OFF // Low-Power Timer1 Oscillator Enable bit (Timer1 configured for higher power operation)
    #pragma config HFOFST = OFF // HFINTOSC Fast Start-up (The system clock is held off until the HFINTOSC is stable.)
    #pragma config MCLRE = ON // MCLR Pin Enable bit (MCLR pin enabled; RE3 input pin disabled)
    // CONFIG4L
    #pragma config STVREN = OFF // Stack Full/Underflow Reset Enable bit (Stack full/underflow will not cause Reset)
    #pragma config LVP = ON // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
    #pragma config XINST = OFF // Extended Instruction Set Enable bit (Instruction set extension and Indexed Addressing mode disabled (Legacy mode))
    // CONFIG5L
    #pragma config CP0 = OFF // Code Protection Block 0 (Block 0 (000800-003FFFh) not code-protected)
    #pragma config CP1 = OFF // Code Protection Block 1 (Block 1 (004000-007FFFh) not code-protected)
    #pragma config CP2 = OFF // Code Protection Block 2 (Block 2 (008000-00BFFFh) not code-protected)
    #pragma config CP3 = OFF // Code Protection Block 3 (Block 3 (00C000-00FFFFh) not code-protected)
    // CONFIG5H
    #pragma config CPB = OFF // Boot Block Code Protection bit (Boot block (000000-0007FFh) not code-protected)
    #pragma config CPD = OFF // Data EEPROM Code Protection bit (Data EEPROM not code-protected)
    // CONFIG6L
    #pragma config WRT0 = OFF // Write Protection Block 0 (Block 0 (000800-003FFFh) not write-protected)
    #pragma config WRT1 = OFF // Write Protection Block 1 (Block 1 (004000-007FFFh) not write-protected)
    #pragma config WRT2 = OFF // Write Protection Block 2 (Block 2 (008000-00BFFFh) not write-protected)
    #pragma config WRT3 = OFF // Write Protection Block 3 (Block 3 (00C000h-00FFFFh) not write-protected)
    // CONFIG6H
    #pragma config WRTC = OFF // Configuration Register Write Protection bit (Configuration registers (300000-3000FFh) not write-protected)
    #pragma config WRTB = OFF // Boot Block Write Protection bit (Boot Block (000000-0007FFh) not write-protected)
    #pragma config WRTD = OFF // Data EEPROM Write Protection bit (Data EEPROM not write-protected)
    // CONFIG7L
    #pragma config EBTR0 = OFF // Table Read Protection Block 0 (Block 0 (000800-003FFFh) not protected from table reads executed in other blocks)
    #pragma config EBTR1 = OFF // Table Read Protection Block 1 (Block 1 (004000-007FFFh) not protected from table reads executed in other blocks)
    #pragma config EBTR2 = OFF // Table Read Protection Block 2 (Block 2 (008000-00BFFFh) not protected from table reads executed in other blocks)
    #pragma config EBTR3 = OFF // Table Read Protection Block 3 (Block 3 (00C000-00FFFFh) not protected from table reads executed in other blocks)
    // CONFIG7H
    #pragma config EBTRB = OFF // Boot Block Table Read Protection bit (Boot Block (000000-0007FFh) not protected from table reads executed in other blocks)
    void main(void)
    OSCCON = 0x72; // 16MHz
    OSCTUNE = 0x00;
    //Set up Special Function Registers
    ANSEL = 0x00; //Enable all input buffers (not using analog functions)
    ANSELH = 0x00; //Enable all input buffers (not using analog functions)
    ADCON0 = 0x00; //ADC disabled
    CM2CON0 = 0x00; //Comparator 2 disabled
    CM1CON0 = 0x00; //Comparator 1 disabled
    CCP2CON = 0x00; //Disable PWM and capture compare modules.
    CVRCON = 0x00; //Disable internal voltage reference (of comparator))
    TRISA = 0b00000110; //AJM checked
    TRISB = 0b00001111; //AJM checked //RB0 is input.
    TRISC = 0b00000000; //AJM checked. //RC2 = Output.
    INTCON = 0x00; //Disable all interrupts
    INTCON2 = 0x80; //Disable PORTB pullups
    SLRCON = 0x00; //All PORTB outputs slow at standard rate.
    PORTCbits.RC2 = 0; //LEDs OFF
    while(1) {
    __delay_ms(1);
    __delay_ms(1);
    return;
  2. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,791
    134
    morristown,tn
    You want this to be off #pragma config LVP = ON // Single-Supply ICSP Enable bit (Single-Supply ICSP enabled)
    That's low voltage programing
    • Like Like x 1
  3. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,007
    316
    Brisbane Australia
    ONLINE
    Remove the return from main.
    • Like Like x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. jjw
    jjw Member
    Apr 16, 2012
    257
    15
    Helsinki, Finland
    What is connected to portb.0 and to portc.2 ?
    • Like Like x 1
  6. Flyback
    Jan 5, 2007
    1,989
    34
    To RB0 we have a pullup resistor and a low side switch which we wired in.
    To RC2 its a BJT which enables disables some LEDs. (via an RC PWM dimmer filter)
    ..this is test code.......the real code is a DALI dimmer and we are receiving dali signals to the pin but it isnt dimming, so we want to see if the micro input pin (RB0) is dead by doing this simple code.
  7. granddad
    granddad Active Member
    Jan 18, 2015
    749
    75
    Worcestershire UK
    To many braces,,,
    while(1) {
    if (PORTBbits.RB0 == 0) PORTCbits.RC2 = 0;
    __delay_ms(1);
    if (PORTBbits.RB0 == 1) PORTCbits.RC2 = 1;
    __delay_ms(1);
    • Like Like x 1
Share This Page
