RF Module of choice for PIC to PIC wireless link
pkshima
All I want to do is to have a biderectional wireless data link between two PICs. I have been searching the whole net but couldnt nail down which RF module is right for me. So thought of seeking guidance here. :rolleyes:
For the time being I am going to use them for remote controlling my bot. PIC attached to PC will send control signals and PIC on the bot will send back sensor data.
So far I can only imagine that either i have to buy 2 pairs of RX/TX pairs or 2 tranceivers.
1) I am unable to judge if I need an ASK type, GSK type PSK etc etc type. been long since i was taught that :eek:
2) With tranceivers, would I have to code up extra to handle its half-duplex/full-duplex nature.
3) With RX-TX pair, how would i ensure that the right pairs are formed so that the PC is not talking to itself and robot doesnt start talking to itself.:eek:
4) Can you help me choose one from https://www.sparkfun.com/commerce/categories.php?cPath=16_79
and
https://www.sparkfun.com/commerce/categories.php?cPath=16_114
and
5) Any hints on where to find the best price.:confused:
The ones used in Nigels tutorial seem to be a bit costly compared to above devices.
I beleive i am ok as per the legal issues given my purpose and the range supported by the above devices.
Mouser has Radiotronix REMOTE CONTROL MODULES in 3 frequencies.
The TX is under $5 and the RX is about $6 for a 300 foot range unit or $17 for a 1000 foot range.
**broken link removed** **broken link removed****broken link removed**
See mouser catalog page.
I have not used these and do not have a clue how well they work. For $10 a pair I may order some just to play with.
Are the linx modules shown at
complete RF modules on a single chip ?
If you want a single chip transceiver, this one is hard to beat;
Some of its features;
* Single +3 To +5V DC supply
* True single chip FSK transceiver 433MHz
* Few external components required
* No set up or configuration needed
* No coding of data required
* 20kbit/s data rate
* 2 channels
* Wide supply range
* Very low power consumption
* Standby mode
All for $26 From Oatley
The xBee are quite large in comparison to the R module I linked, and require 3.3V to operate (not to mention a breakout board), so chances are you will need two supplies and some sort of buffer for data transfer if your not using a 16LF or 18LF PIC
They also have a fair bit off setting up in comparison too..
nickelflippr said:
I wish there were cheap rf transeiver 'modules'. Please post if you have found any less than $20 ea.
These are the best tranciever's I've ever seen, and at less than $20 they are a *steal*!!
https://www.sparkfun.com/commerce/product_info.php?products_id=705
...each transceiver has 6 internal data pipes... meaning you can set one up as a receiver to 6 others, make mesh networks, etc. etc. etc. Lots of hardware assist in error recovery and re-transmission and an easy to use SPI interface to your favourite micro makes using them a snap.
Regards,
Paul
