    Dismiss Notice
RF COMMUNICATION WITH MICROCONTROLLER
Discussion in '8051/8951' started by ORGENES, Feb 3, 2016.
  1. ORGENES
    ORGENES New Member
    Feb 3, 2016
    6
    0
    Hi everyone..
    I work on project of message sending between two micro controllers using RF modules. Help me the choice of micro controllers and RF modules. Also help me on circuit diagram.
  2. ericgibbs
    ericgibbs Well-Known Member Most Helpful Member
    Jan 4, 2007
    21,187
    644
    Ex Yorks' Hants UK
    We need more information about your project.
    eg: distance between the two MCU's, data transmission rates etc.
    E
  3. ORGENES
    ORGENES New Member
    Feb 3, 2016
    6
    0
    Thanks, Distance between micro controllers is 100metre which is the distance between transmitter and receiver since one micro
    controller is at transmitter and another at the receiver.
    Also data transmission rate to be 10kbps.
    operating frequency of RF modules 433MHz.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,049
    541
    AZ 86334
    100meter range will work only with very good antennas, both at the transmitter and at the receiver (not just a pcb trace or a whip: must be full dipole, likely outside). Will work only if not blocked by another transmission on the same (shared) frequency. 315Mhz works better in urban areas; 433Mhz is hopeless in urban areas because of all the other uses of that frequency.
    If you dont believe this, listen near 433.92MHz +- 50kHz on a scanner.
    • Like Like x 1
  6. ORGENES
    ORGENES New Member
    Feb 3, 2016
    6
    0
    Thanks Mike,
    Can i helped on block diagram and circuit?.
  7. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    ONLINE
    I just used a pair of ZigBee modules. Just sent the output in whatever format you want (1-wire + ground), receive with the mated module and you are done.
    John
  8. atferrari
    atferrari Well-Known Member
    Oct 8, 2003
    2,812
    121
    Buenos Aires - Argentina
    Steep learning curve, John?
    Realistic distance in line of sight?
    What modules did you use?
  9. gophert
    gophert Active Member
    Jan 17, 2015
    197
    30
    Western, PA (USA)
    If it is the cheap 433MHz modules from eBay, you will be lucky to get 8kHz across the room.
  10. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    ONLINE
    atferrari M
    Model S1 XBee from a few years ago. Adafruit adapter board. Range about 6 m line of sight with no antenna on either end. The plug functions as the on/off switch and for battery charging. Batteries are Li-ion. The cover has a matching hole, which can be plugged to make it reasonably watertight when in use. The sensor is under the XBee and is my Memsic accelerometer.
    John
    • Informative Informative x 2
  11. ericgibbs
    Jan 4, 2007
    21,187
    644
    Ex Yorks' Hants UK
    I use the NRF24L01 2.4GHz transceiver, the best I can get using the PCB etched antenna is 8 metres thru a brick wall.
    Both the Base and Remote TXR pcbs are mounted vertically.
    The project is a Base station with 4 Remotes/Pipes.
    I do have some 2.4GHz dipole antenna's which I plan to try, when the weather improves.:)
    Web posted documentation suggests that with a dipole I should get 100 metres.
    E
  12. granddad
    granddad Active Member
    Jan 18, 2015
    750
    75
    Worcestershire UK
  13. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    ONLINE
  14. NorthGuy
    NorthGuy Well-Known Member
    Sep 8, 2013
    1,218
    206
    Northern Canada
    I don't think you can achieve 10kpbs with 433MHz at 100m.
    I have built few RF gadgets to control things on my land. They exchange short messages at 1kpbs. The distances are perhaps a little bit longer than 100m in some cases, and there's some trees in between. I used ready-made Linx modules, so there's not much of a cirucuit except two wires from MCU to the module and a wire from the module to antenna. Antenna helps a lot. I use simple ones, but you can use directional Yogi antenna. It is supposed to work better, but I haven't tried it myself. You also must use some narrow-bandwidth encoding, such as Manchester, otherwise it's totally hopeless.
  15. ORGENES
    ORGENES New Member
    Feb 3, 2016
    6
    0
    Thanks i get u good Mr North Guy, and i think you have more knowledge, so what you advice me? and can you give a circuit diagram?
    I got you that, i should use 1kbps and a distance of about longer 100m, so how the circuit will be to achieve this?
  16. MikeMl
    Mar 17, 2009
    11,049
    541
    AZ 86334
    It is all about using a complex protocol that validates messages (checksums, parity, sending it multiple times), because any given transmission can be stepped on by another (unrelated) 433MHz transmission. You have no control of who else is using the frequency.
    The simplistic super-regenerative receiver in those inexpensive modules you bought locks on to the strongest signal it hears within +- about 2Mhz. If you are trying to get long range, your own transmission will be very weak, and subject to getting clobbered by other signals. Antenna gain, and directional antennas will help some, but that also receives the interfering signals better:(
  17. NorthGuy
    Sep 8, 2013
    1,218
    206
    Northern Canada
Share This Page
